gshamusphoto Posted April 27, 2015 Share Posted April 27, 2015 Sorry if this has been covered. I am considering buying a Variax guitar and have a question. I use both a M13 and am now playing with the new Firehawk. Do you need to use a Line 6 amp to utilize all the functions of the Variax guitar? I play through a Late 80's Matchless amp and am not really looking to replace it with a line 6 one. I do have a Spider Valve HD 100 head that I bought off Ebay used but have not really dug into using it much. Any info you guys could provide would be great. I am most interested in the acoustic settings and the capo settings. I also use a Line 6 wireless unit, maybe I can run a cable for my electric use and the wireless for the acoustic use. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
radatats Posted April 27, 2015 Share Posted April 27, 2015 makes no difference what amp you use with the Variax... at least the Firehawk fully supports the Variax which is helpful. Does the Matchless have an FX loop? I'm sure you know modellers tend to work better going straight into the power section of a guitar amp if possible... Quote Link to comment Share on other sites More sharing options...
gshamusphoto Posted April 28, 2015 Author Share Posted April 28, 2015 makes no difference what amp you use with the Variax... at least the Firehawk fully supports the Variax which is helpful. Does the Matchless have an FX loop? I'm sure you know modellers tend to work better going straight into the power section of a guitar amp if possible... It does have aloop. Although I have not used it since I play faintly clean and then add my gain with pedals. Quote Link to comment Share on other sites More sharing options...
ppiluk Posted April 28, 2015 Share Posted April 28, 2015 I run my POD HD500 into the effects loop of my amp. It sounds fantastic! You only need to run one cable from the Firehawk to the the Power Amp section of the effects loop. Quote Link to comment Share on other sites More sharing options...
