problem with model packs podhd500x
rojitolijo2fg
Ive already installed on my pod hd 500x the model packs, but the most of the amps , are in " PRE "  option only, in think is the " pre amp" models , but just only like 6 o 7 amps are just the name ,  thats normal ? what im doing wrong ? i just installed as the instructions on the line6 page explains.
no, that's right.
I mean, I don't have an actual count. But I know that most of the new amps are pre only.
Any reason for that?
Good to know, I almost never use Pre version of the amps, so model packs would be quite useless for me.
No, this information is incorrect. There should be more regular models than Pre models as some of the new models are ported from the XT, which didn't have Pre models.
All models will appear as regular models, many will have Pre versions too, but not all.
Don't ignore the Pres! They give you a whole 'nother set of sounds to choose from. Many are quite a bit different from their Full counterparts. Treat just like another amp choice.
I found the pre versions great when using an actual amp. I found them incredibly terrible when going FRFR which makes sense because a pre amp with no power amp, speakers, or mic isn't expected to sound good.
-Max
Thanks for clarification
Maybe I should give them more attention. I always saw them as for using with an external amp. Since I'm mostly play through my headphones and tweak the speaker options a lot I never gave much attention to the Pre's
  • 3 weeks later...
The following new amps have pre models:
A30 Fawn Brt
A30 Fawn Nrm
Brit 2204
G Cougar 800
Jazz Rivet
Mahadeva
Mandarin 80
PV Panama
Small Tweed
SVT Brt
SVT Nrm
The following amps do NOT have pre models:
1x8 Champ
212 Jazz
410 Rhino
810 SV Beast
Acoustic
Aggro
Big Bottom
Black Panel Pete
Insane
Jazz
Octone
Purge
Smash
Variac'ed Plexi
