janaleks Posted June 21, 2015 Share Posted June 21, 2015 Hei. I have been latelly experiencing that my jm4 is having and odd behavior. The Lcd screen suddenly shows that the volume is being moved while playing. Evenmore, it can happen while trying to hit play or stop on an overdub not allowing the action to take effect and even not allowing to record while it happens. It also happens very often, I would say with intervals of 10 to 15 secs or less but it is not a fixed time. I have come to the idea that the volume knob is damage. I am wondering if somebody else is experiencing the same problem? Eventually if this is due to the volume knob where could i posiblly get a replacement or what type of knob should i get for this equipment Thanks Jan 1 Quote Link to comment Share on other sites More sharing options...
pietwelve Posted November 1, 2019 Share Posted November 1, 2019 It looks i've got the same, or a similar problem. I'm playing (guitar -> JM4 -> mix table ) and suddenly volume drops A LOT. It happens more and more often. if I unplug and replug the jack into the guitar volume comes back. if I unplug and replug main alim into JM4 the guitar volume comes back. Any chance someone knows how to deal with that ? Thanks Quote Link to comment Share on other sites More sharing options...
overide69 Posted January 25, 2022 Share Posted January 25, 2022 Have exactly the same but after update in 2.09 and card formatted, it's every time in minuts now, before was 10-15s, someone found a solution ? Quote Link to comment Share on other sites More sharing options...
Maria987 Posted January 13 Share Posted January 13 It sounds like your Line 6 JM4 Looper is suffering from "ghost editing." This happens when the internal part of the volume knob, called a potentiometer, becomes dirty or worn out. Even a tiny bit of dust or oxidation inside can create "jitter," making the pedal think you are turning the knob when you aren't. This interrupts your playing because the software prioritizes knob movements over foot commands, which is why your recording and playback are freezing up. To fix this, try spraying DeoxIT (an electronic cleaner) into the base of the knob and turning it vigorously. If that fails, you need a replacement 10k Ohm linear potentiometer. You can find these at electronics parts stores like Mouser or Full Compass. Any technician can solder a new one in for you. Since this is a common issue with older Line 6 gear, Ome TV, a new part should make the pedal feel brand new again. Quote Link to comment Share on other sites More sharing options...
