theiser40 Posted July 13, 2015 Share Posted July 13, 2015 Hi I just got the trio how I connect it to my firehawk for best sound. Just downloaded the new software for firehawk to 1.10. Thanks Quote Link to comment Share on other sites More sharing options...
Varialogue1 Posted August 3, 2015 Share Posted August 3, 2015 My trio arrived today. Has anyone worked out the best setup with the firehawk? Quote Link to comment Share on other sites More sharing options...
Varialogue1 Posted August 3, 2015 Share Posted August 3, 2015 Has anyone worked out the answer to this important question? My trio just arrived Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted August 4, 2015 Share Posted August 4, 2015 What's a trio? Quote Link to comment Share on other sites More sharing options...
stevekc Posted August 4, 2015 Share Posted August 4, 2015 Digitech Trio http://www.vguitarforums.com/smf/index.php?topic=13528.0 Quote Link to comment Share on other sites More sharing options...
radatats Posted August 4, 2015 Share Posted August 4, 2015 I love my Trio but I use it with a HD500 so it's a little different. In the HD500 I can set up dual paths with one for guitar and the other for the Trio. See my post below. With Firehawk you only have one path so its different. I think your only real option is to go from the Firehawk into the Trio and then to your amp/PA. Use the correct output from the Trio accordingly. If you are using a PA or monitors, you should be able to run one Firehawk out to the PA and the other to the Trio. Now send the Trio mix output to the PA too with a dummy plug in the Trio amp output. That will give you the pure Firehawk amp tone in one channel and the clean drums and bass on the other channel. Run it in mono and it will sound great. If you are using a guitar amp, just run from the Firehawk to the Trio to the amp. You really have no other choice... http://line6.com/support/topic/14706-hd500-with-digitech-trio-pedal/ Quote Link to comment Share on other sites More sharing options...
urbanspaceblast Posted August 4, 2015 Share Posted August 4, 2015 My amp has an FX loop so I use the 4 cable method. The Trio is the last thing in the chain before the signal goes to my amp return. 1 Quote Link to comment Share on other sites More sharing options...
stevekc Posted August 4, 2015 Share Posted August 4, 2015 Just know that the TRIO may not track your chords if any modulation FX, Delay FX are enabled and upstream of the Digitech TRIO Input Quote Link to comment Share on other sites More sharing options...
Varialogue1 Posted August 4, 2015 Share Posted August 4, 2015 Cheers guys. I'm a simple man with simple tastes so guitar to firehawk to trio to amp it is. Quote Link to comment Share on other sites More sharing options...
urbanspaceblast Posted August 4, 2015 Share Posted August 4, 2015 Well you did ask for the best way B) Providing you keep your amp as clean as possible you'll be fine. Drums with overdrive sounds like donkey. Quote Link to comment Share on other sites More sharing options...
