Tboneous Posted July 20, 2015 Share Posted July 20, 2015 I'm sure this has been asked before but I can't seem to find the answer What is recommended when you are running 2 DT's and a Stage source speaker in terms of order? Which one should come first, second and third out of the Pod? Does it matter? Thanx Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted July 20, 2015 Share Posted July 20, 2015 I don't have a DT, but my memory of previous threads is that a DT has to come before a StageSource otherwise some aspects of functionality are compromised. I don't remember anybody with two DT amps and StageSource in a combined rig before! Quote Link to comment Share on other sites More sharing options...
Tboneous Posted July 20, 2015 Author Share Posted July 20, 2015 I don't have a DT, but my memory of previous threads is that a DT has to come before a StageSource otherwise some aspects of functionality are compromised. I don't remember anybody with two DT amps and StageSource in a combined rig before! Thanx. I kinda figured that the DT would come first. But what about the second DT and the L2M? Should it be DT-->L2M-->DT or DT-->DT-->L2M? I also wonder if a particular configuration will finally allow me the ability to save my L2M settings. For the life of me, I can't get that damn speaker to save its settings. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted July 21, 2015 Share Posted July 21, 2015 I don't know if this helps; you have probably read it already: http://line6.com/data/6/0a06434d41f050904bee355b1/application/pdf/L6%20LINK%20Connectivity%20Guide%20for%20POD%20HD%20&%20DT%20Amplifiers%20v2.10%20-%20English%20(%20Rev%20A%20).pdf I have just found it myself, and it might contain the answer to how to have stereo monitors using the L6 LINK: AUDIO configuration. Got to try that when I get home Quote Link to comment Share on other sites More sharing options...
Tboneous Posted July 21, 2015 Author Share Posted July 21, 2015 I don't know if this helps; you have probably read it already: http://line6.com/data/6/0a06434d41f050904bee355b1/application/pdf/L6%20LINK%20Connectivity%20Guide%20for%20POD%20HD%20&%20DT%20Amplifiers%20v2.10%20-%20English%20(%20Rev%20A%20).pdf I have just found it myself, and it might contain the answer to how to have stereo monitors using the L6 LINK: AUDIO configuration. Got to try that when I get home Thanx. Yes I have read it and re-read it. It shows you how to hook up to 4 DT's but says nothing about a DT/L-series configuration. It's a bit odd that no one has a real answer. to this one. Quote Link to comment Share on other sites More sharing options...
Tboneous Posted July 26, 2015 Author Share Posted July 26, 2015 I think I finally figured this amp order thing out. If you want to save different settings on your L -series speaker per patch, the L-series must come first out of the POD. Now I have to go and reconfigure all of my patches cause I assumed the DT was the logical choice for first in line. Line 6, it sure would be helpful to many if you would put that nugget in the manual. It sure would have saved me some grief. But hey....yet another really good reason to go play with my gear! Quote Link to comment Share on other sites More sharing options...
samsgs Posted August 29, 2015 Share Posted August 29, 2015 Hadn't been on these posts in awhile. I have been running 2 DT25's from POD HD500X, and then from DT's to L3t. All connected with L6 link and VDI to JTV 69 Variax. Thought it sounds good. I don't understand but hope you can help. How does the L series "save" settings? Does it help? How does it matter as long as the POD remembers? Just curious. Would appreciate your thoughts on if your configuration is better with the L series first, then 2 DT's. What settings are you using on your mixer for the L series. Amp A or B or A/B, L, R, L&R? Would the L series then become Amp A or B in the mixer? Shpank I'm confusing myself now. In short, is it better. Quote Link to comment Share on other sites More sharing options...
