deo33 0 Posted August 3, 2015 Hi all, Why is the Blackface model so quiet? I can blow the windows out with the Marshall amps and channel volume on 3, but when I set up a Blackface I can crank it all to 10 and it's no where near the same volume. I have tried the BF with different topologies, etc and it's the same issue. WTF??? Is this normal, or is there something wrong with my amp.??? Quote Share this post Link to post Share on other sites
Palico 132 Posted August 3, 2015 Why, I don't know but yea topology I is quieter than the rest by quite a bit. So your amp is working properly. Quote Share this post Link to post Share on other sites
shaker 1 Posted August 4, 2015 It's ridiculous! The Twin is a big loud amp yet the Line 6 model is tiny and quiet! I ended up using the Bassman model on topology II to boost the volume up.... Quote Share this post Link to post Share on other sites
Palico 132 Posted August 4, 2015 It's ridiculous! The Twin is a big loud amp yet the Line 6 model is tiny and quiet! I ended up using the Bassman model on topology II to boost the volume up.... If your using POD HD unit with the DT you could change the topology and still use the Twin amp model. Not sure how it would sound but the point of the rig is that you can set it anyway you want, even setups that never really existed. No rules the end resulting tone is all that really matters. Quote Share this post Link to post Share on other sites
shaker 1 Posted August 5, 2015 You don't need a POD to change the Topology, it can be done through DT edit, but the Twin model should be much louder by default Quote Share this post Link to post Share on other sites
Palico 132 Posted August 5, 2015 You don't need a POD to change the Topology, it can be done through DT edit, but the Twin model should be much louder by default Oh yea forgot about the DT Edit. And yea I agree. Any amp on Topology I is quite. Even the Soloando ones. Not sure why they made it that much quieter than the others cause like you said a real Fender twin has 3 volume settings, off, loud and louder! Quote Share this post Link to post Share on other sites
geppert 110 Posted August 5, 2015 Deo33 ... Agreed that TOP I is very quiet compared to the others. I discovered that increasing the Gain doesn't grunge the Twin up too much so I ran the channel volume full out and set the gain up to 2-3+ o'clock to accomplish some better volume equilibrium. See if that might work for you at all? If you are using TOP 1 for clean tones against any of the other TOPs for grunge you will have to turn the Channel Vol down on the grunge's to equate. Just the way it is with this amp. That all being said, this is one great amp once you get your head around it imho. I ended up switching to one of the Brit models (sorry, don't have my HD500 in front of me but I think it is the P75) for clean tones. I prefer it over the Twin, plus it has more overall gain and matches better to the grungier tones for volume equality. 1 Quote Share this post Link to post Share on other sites
BucF16 45 Posted August 27, 2015 I seem to remember that the recommendation for the twin is to dime the gain and then the channel volume is really your distortion. Never owned a twin but supposedly this is how some people use that amp. Quote Share this post Link to post Share on other sites
mtreehugger 51 Posted September 3, 2015 Hi all, Why is the Blackface model so quiet? I can blow the windows out with the Marshall amps and channel volume on 3, but when I set up a Blackface I can crank it all to 10 and it's no where near the same volume. I have tried the BF with different topologies, etc and it's the same issue. WTF??? Is this normal, or is there something wrong with my amp.??? If you read the literature, they tell you that the volume disparity between amp models is a deliberate design choice made for the sake of authenticity. IMO it's either a very poor choice or a load of B.S. to cover a design flaw. Either way, you have to set each patch's "amp's" (i.e. patch or channel) volume with respect to the other(s)' by lowering the high output one(s) to match with the Fender. BTW, I'm not a chick, this is my next GF once I track her down... Quote Share this post Link to post Share on other sites
deo33 0 Posted December 27, 2017 Thanks all for the feedback! \m/ Quote Share this post Link to post Share on other sites
psarkissian 354 Posted December 27, 2017 Also, make certain the volume control shaft is in for full volume, and not out in the lower volume mode. It's an easy thing to forget. Quote Share this post Link to post Share on other sites
themager 0 Posted January 12, 2018 Know this is an old thread, but the volume disparity between voice 1 and the rest is my biggest grievance with the amp. I think I suffered permanent hearing loss the first time I played it , changing from voicing I to 2. Ended up using the DT Edit to put quieter amp models on channel A and the louder ones on Channel B. Quote Share this post Link to post Share on other sites
