Pod mutes Path B when changing patch
manatopain
Hi everybody!
i just spent the last hour creating a really beautiful patch and i have it saved and all.
but sadly, when i go from the patch to another patch, and then return to the patch, the path B is muted! inside the mixer, it stays on the same, +0.0dB which it is saved as, but the path is - as said - muted. I only need to click on the mixing slider, and the path is returned to +0dB - although there is no visual change in the slider.
can anybody help me with this? It's really annoying, and pretty much makes the patch useless, if i can only listen to the path B while im editing the patch.
Notes: I'm editing the patch in pod HD500 edit. Patch is attached.
  • 1 month later...
hi
this is a known bug
it has to do with the edit software communication with the pod
the workaround is: when this happens, after you send the correct patch to the pod you need to also save the patch on the pod itself (by pushing the save button 2 times)
this didn't work for me. I tried exactly what you suggested:
1st  I dragged and dropped the patch into the Pod HD edit, and the Path A was muted, even though the indicator was at -4dB.
2nd I moved a bit the level of the Path A and placed it again at -4dB, so it can work well again.
3rd  I clicked twice the "Save" button on my Pod HD
4th I changed the patch with another from the saved ones and then I changed back to the patch that has the bug and it still had that bug
Am I doing anything wrong here? :/
Ok I just made it work. This time I just corrected the mixer by using the Pod's buttons entirely and then double-clicked "Save" and now it works! Thank you so much, perapera!
Nevermind, it didn't work. When I keep adding patches in the setlist, the bug returns and I need to fix it again. Thanks, Line 6 -.-
I've noticed something similar when a patch has a foot switch assigned to one of the two amps in the signal path.  One amp winds up turned off.  So I have to double-check all foot switch assignments. I don't assign FS to amps so assuming this happens when footswitch assignments are edited for other effects.
