Punkyboy Posted October 15, 2015 Share Posted October 15, 2015 hello is it possible to save a preset on the Pod HD 500x with a preset on the variax like this ex: I make a tone on 500x with acoustic sound on the variax switch position 1 on switch A of the pod and make a preset on 500X with a spank sound on variax switch position 3 on B of the pod and now just switch between A and B of the pod, without change the position of the guitar switch so ex I can switch between acoustic and distortion is this possible or do I need to replace the guitar switch on the good position everytime? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 15, 2015 Share Posted October 15, 2015 Yes you can do that as long as you use the VDI connection between Variax and Pod. You won't need to touch the Variax guitar switch. You can also store/recall the position of the Variax Tone knob with the Pod preset. And you can even set things so that you can use the Variax Vol and Tone knobs to control FX parameters on the Pod. How about using the Variax Tone knob to control the Delay Feedbak, for instance? Or the Chorus Depth? Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted October 15, 2015 Author Share Posted October 15, 2015 ok I have the VDI connection Silverhead can you explain me how to do that ? please just simple to help me understand Thanks man Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 15, 2015 Share Posted October 15, 2015 - connect using VDI - set one of your preset Inputs to Variax - use the Variax to select the model, pickup switch, and Tone knob positions - SAVE the preset on the Pod That's it. For further detailed instructions, including how to control alternate tunings and to use the Vol/Tone knobs as FX controllers you should read the POD HD500X manual. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted October 15, 2015 Author Share Posted October 15, 2015 hmmmm I do that , but not working when I switch the guitar switch and change the pod preset from A to B and come back to A, it stay on the variax preset just switched I got test it tomorow , because it's late here now ahah But I let you know Tx Man Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 15, 2015 Share Posted October 15, 2015 You may have to go to the Variax page in the Setup menus and make sure your Variax control is not set to Don't Force. That setting means that your Pod is prevented from controlling the Variax. There are other things, too, that could be wrong with your settings or usage. You'd really be best to read the relevant sections of the manual. EDIT: You should also remove the battery from your Variax when connecting via VDI. That connection powers the Variax. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted October 16, 2015 Author Share Posted October 16, 2015 Allright Man I set up to "Force" and it's ok, thanks a lot greetings Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 16, 2015 Share Posted October 16, 2015 Glad you got it working. Quote Link to comment Share on other sites More sharing options...
Nicky-T Posted January 7, 2019 Share Posted January 7, 2019 I'm a longtime Variax user, and new to the POD HD500X. I want to set the Variax Model (Jazz-5) to remain in effect, but have the Tone and Volume controls work normally. The Variax section in the Mixer has 5 options: None, Volume Lock, Tone Lock, Vol+Tone Lock, and Vol+Tone+Togl Lock. So there is no setting for Togl Lock separately from Volume and Tone! I did find a workaround. I set the amp's Ch Vol controlled by Variax Vol and the amps's Treble to the Variax Tone. This setting will lock the Model Selector and leave the other two controls to their assignments. Kind of a pain, and not what I wanted. Can't find any other way to do it in the manual. Seems like such a simple thing. Quote Link to comment Share on other sites More sharing options...
