TYLERINO85 0 Posted October 20, 2015 Hello guys, I've a question. Can I connect my Line 6 UX1 to an amp output with a cable like this for use the amp's speaker (1/4 jack to two RCA) ? http://www.amazon.co.uk/Cable-Stereo-Phono-Jack-6-3mm/dp/B008R71FJI Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted October 20, 2015 Are you trying to route the UX1 into an amp, or route an amps output to your UX1 for processing? Quote Share this post Link to post Share on other sites
TYLERINO85 0 Posted October 20, 2015 hello and thank you for the reply. I'm trying to route the ux1 in the amp only for use the amp's speaker, just this. I want to hear the ux1's sound from the amp's speaker. Quote Share this post Link to post Share on other sites
silverhead 8,878 Posted October 20, 2015 The UX1 has 2 1/4" analog outputs (stereo) - not RCA - so the cable you identified is not the one you want. You also need to consider the type of input on your amp. Is it mono or stereo? 1/4" or something else? Quote Share this post Link to post Share on other sites
TYLERINO85 0 Posted October 20, 2015 My amp is a Fender frontman 15r, he has an headphone output jack, and an aux in input (stereo maybe) So I'm trying to connect the 1/4" analog output of the ux1 in the aux in input of my fender ( with two rca )... isn't correct? Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted October 20, 2015 You can run a regular guitar cable from the Left Analog out to the front of your amp or use a 1/4 to 1/8 adapter to use the aux in. The amp is not stereo, but the aux in likely mono sums a stereo input. Quote Share this post Link to post Share on other sites
TYLERINO85 0 Posted October 20, 2015 Maybe I've understand... I can connect the headphones input on the front of the UX1 to the input on the front of my amp ( the same I use to plug in my guitar in the amp, it's right ? ) with a regular 1/4" guitar's cable? Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted October 20, 2015 I would use the Left Analog out. The headphone output is stereo. If you use the headphone output I would us the Aux in on the Fender Quote Share this post Link to post Share on other sites
TYLERINO85 0 Posted October 20, 2015 aaaah , ok , you are talking about the "line inputs" on the rear of the UX1 , it's right ? So , I've to connect the line input on the rear of the UX1 with a regular 1/4 "cable directly into the input of my amp , where i connect my guitar when i play with the fender , right ? Quote Share this post Link to post Share on other sites
TYLERINO85 0 Posted October 20, 2015 while , if I use the headphone output on the UX1 , I connect it at the input aux in on my amplifier... it's right? Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted October 20, 2015 aaaah , ok , you are talking about the "line inputs" on the rear of the UX1 , it's right ? No, the analog Left out. Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted October 20, 2015 while , if I use the headphone output on the UX1 , I connect it at the input aux in on my amplifier... it's right? Yes. Quote Share this post Link to post Share on other sites
TYLERINO85 0 Posted October 20, 2015 No, the analog Left out. Ok it's Clear now, thank you man. Just a question, I've to use a 1/4 stereo (for The ampli input jack) to two mono 1/4 (for The analog plug L/R on ux1)? Or Just a simple Guitar Cable with one jack in The ampli input and the other jack in one of The analog plug ( or L or R )? Quote Share this post Link to post Share on other sites
TYLERINO85 0 Posted October 21, 2015 That's in the manual: "Analog Outs - These Left and Right unbalanced jacks output all the audio from UX1 - The audio from your audio software on the computer, and anything plugged into any input. These are what you want to connect to your powered speakers or monitoring system for a recording setup. Use 1/4-inch cables to connect directly to powered speakers, mixer or power amp setup. Note that you can also use the headphone jack on the front of UX1 if you want to use headphones for monitoring." So, it's correct what You say, I must to use a cable with 2 1/4" jacks for the analog plugs on ux1 and 1 1/4" jack on the amp input. Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted October 23, 2015 You can just use one since your amp is not stereo. Quote Share this post Link to post Share on other sites
Sandyfeet 0 Posted November 16, 2016 I'm wondering if you can use both analog outs to two different ( smaller) amps? Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted November 22, 2016 I'm wondering if you can use both analog outs to two different ( smaller) amps? Absolutely!! Quote Share this post Link to post Share on other sites
Sandyfeet 0 Posted November 22, 2016 Thanks!! Quote Share this post Link to post Share on other sites
