pwh589 0 Posted December 2, 2015 my distortion is better than the pods,but the problem is that ifi use my amps distortion,it affects all the efects,like reverb n stuff.i want to put the distortion first in the chain of effects,but i want to use my distortion from my amp not the pods distortion Quote Share this post Link to post Share on other sites
pianoguyy 412 Posted December 2, 2015 my distortion is better than the pods,but the problem is that ifi use my amps distortion,it affects all the efects,like reverb n stuff.i want to put the distortion first in the chain of effects,but i want to use my distortion from my amp not the pods distortion fx loop not only of the unit, but of the amp as a well. Various hookups will allow different things. Quote Share this post Link to post Share on other sites
cruisinon2 2,534 Posted December 2, 2015 my distortion is better than the pods,but the problem is that ifi use my amps distortion,it affects all the efects,like reverb n stuff.i want to put the distortion first in the chain of effects,but i want to use my distortion from my amp not the pods distortion The 4 cable method (4CM) will allow you to do what you want. There are 1000 threads on here describing it. A quick search will provide at least a week's worth of reading material. 3 Quote Share this post Link to post Share on other sites
Gfer1484 2 Posted December 5, 2015 I use my distortion first in the single chain, set your first effects block to FX, you will need two patch cables to go from FX send to FX return on the pod with your pedal in the chain, and set the switch on the back of the pod to stomp. Quote Share this post Link to post Share on other sites
