dr150
DT25 112 Combo....HUGE Electrical Noise...Any Ideas?...
Just received a new DT25 112 Combo amp and having issues.
There's a very high/noticeable amount of electrical noise using this amp in ANY setting (any dial...i.e. drive, presence, volume, master, class A/AB, pentode/Triode, etc).  The electrical noise only quiets down when you reduce the volume to too low a volume.
Already at 10 o'clock dial setting the noise is marked....and every setting in the recommended Voice plastic cutout sheet that came with the amp is noisey as hell.  Overdrive is a joke in noisiness.  Cleans should be silent and aren't.
Power cord is in a balanced electrical outlet and cables are shielded.
I've had tube amps before in same wall socket/cables and none were as electrically noisey as this unit. It's deal breaking annoying.
MY GUESS:
1.)  Bad tubes
2.)  Broken unit  (i.e. needs servicing)
Any advice?.....
My #1 suspect in this case would be one or more tubes.  It's possible that one might not be seated well after shipping.
MY GUESS:
1.)  Bad tubes
Any advice?..
Maybe you should do a support ticket if it's new.
MY GUESS:
1.)  Bad tubes
Any advice?.....
Is it hum or fizz?
hum:
1. earth loop
2. bad insulation
fizz:
1. bad grounding on your guitar
2. bad cable
plus your ideas.
To try to isolate the problem I would (maybe you have already done this):
1. try another cable
2. try another guitar
3. try nothing plugged in and turn the amp up. See if the buzz is still there with no input signal
Create an account
Register a new account
Sign in
Sign In Now
