MusicJoshua Posted July 30, 2013 Share Posted July 30, 2013 Hey all, I just got my POD HD 500 so I might have missed an answer along the way but... I am having trouble being able to switch certain effects on and off while a loop is running. Am I doing something wrong or do I have something assigned incorrectly? Thanks, JM Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 30, 2013 Share Posted July 30, 2013 You have to hit the looper switch to go out of looper mode and back into the preset you're in if you want turn effects on and off. Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 30, 2013 Share Posted July 30, 2013 I have found that it is very difficult to do the required tap-dancing between Looper mode and Perfomance mode to use the HD500 Looper effectively for live play. I can never keep the tempo properly while trying to coordinate all the required tapping. For me the HD500 Looper is a practice utility (playing solo over a looped backing track recorded in POST position) and a tone-seeking utility (changing presets and tweaking manually over a sequence recorded in PRE position, allowing you to tweak without playing) Quote Link to comment Share on other sites More sharing options...
