artkingjw Posted January 26, 2016 Share Posted January 26, 2016 Hello guys, I've got a question about what the Helix can do as far as FX loops go. Tried searching for this but haven't seen anything that answers this question, maybe I just haven't used the right terms. Can the Helix amp model blocks have an FX Loop within them, between the pre and power amp. In otherwords, just like my real life amp, there is a 'send' after the pre-amp, and a 'return' feeding into the power-amp. Guitar > Pre-amp > FX Loop > Power-amp > Cab My understanding is it cannot be done, with the closest thing possible being: Guitar > Pre-amp > Power-amp > FX Loop > Cab I'm not the most skilled when it comes to this sort of stuff, but I have been playing around with Line 6 gear for a while now, currently own a HD500, considering an upgrade to the Helix. I'm used to setting my delays and reverbs up like this to control the amount of distortion of the trails, as well as for different effects on modulation. Thanks Quote Link to comment Share on other sites More sharing options...
TheDaveDaveDave Posted January 26, 2016 Share Posted January 26, 2016 No, it's not possible because the Helix's amps only come in "Preamp" and "Amp" variations, where "Amp" is the preamp and power amp. You can put effects and loops between a full amp model and it's cab by disabling the amp models cab and adding a discrete one. While this may not be what we're used to, consider that almost all the studio recording you've ever heard have a mix of effects before the preamps and post mic/cab. The few times I've been in the studio, the engineer SHUDDERS when I use the effects loop. The original invention of the effects loop was to try to get a live sound that is closer to a studio sound, where time domain effects are after the mic/cam combination. So in one respect, Helix and most other modelers are a step up from the good old days of FX loops of real amps, but it's still a shame that we can't do it if we want to because of the missing free-standing power-amp models. Back to the other side of the coin: a delay hitting your phase inverter and power tubes will make for a different kind of breakup, which can be really special sounding... It's odd that we can do this with the Helix in a 4CM configuration, but not in standalone config with amp modeling along :( Hope this helps, Dave 1 Quote Link to comment Share on other sites More sharing options...
artkingjw Posted January 26, 2016 Author Share Posted January 26, 2016 No, it's not possible because the Helix's amps only come in "Preamp" and "Amp" variations, where "Amp" is the preamp and power amp. You can put effects and loops between a full amp model and it's cab by disabling the amp models cab and adding a discrete one. While this may not be what we're used to, consider that almost all the studio recording you've ever heard have a mix of effects before the preamps and post mic/cab. The few times I've been in the studio, the engineer SHUDDERS when I use the effects loop. The original invention of the effects loop was to try to get a live sound that is closer to a studio sound, where time domain effects are after the mic/cam combination. So in one respect, Helix and most other modelers are a step up from the good old days of FX loops of real amps, but it's still a shame that we can't do it if we want to because of the missing free-standing power-amp models. Back to the other side of the coin: a delay hitting your phase inverter and power tubes will make for a different kind of breakup, which can be really special sounding... It's odd that we can do this with the Helix in a 4CM configuration, but not in standalone config with amp modeling along :( Hope this helps, Dave oh? I never knew that, thanks. But man, yes have I fallen in love with the delays and reverbs hitting a stressed power section. Sad we can't do that... Actually with modularity being more of a thing with the Helix, I wonder if they can program that in and deliver it as a future update? Quote Link to comment Share on other sites More sharing options...
Dshow Posted January 26, 2016 Share Posted January 26, 2016 No, it's not possible because the Helix's amps only come in "Preamp" and "Amp" variations, where "Amp" is the preamp and power amp. You can put effects and loops between a full amp model and it's cab by disabling the amp models cab and adding a discrete one. I always thought it would be behave like this - the effects placed before the amp block in helix would behave the same as I would put them between Guitar and Input of the real amp - the effects placed after the amp block in the helix is routed like I would place them in the effects loop of a real amp Quote Link to comment Share on other sites More sharing options...
artkingjw Posted January 26, 2016 Author Share Posted January 26, 2016 I always thought it would be behave like this - the effects placed before the amp block in helix would behave the same as I would put them between Guitar and Input of the real amp - the effects placed after the amp block in the helix is routed like I would place them in the effects loop of a real amp If my experience with the HD500 is anything to go by, I don't think so, although I could be wrong. For instance, when I place a Tape Delay (wet) behind a full amp, it craps itself. I always felt a bit of a bummer never being able to put the tape in the FX loop, where it probably won't sound so buzzed out, but still carry the dirt from the pre amp. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 26, 2016 Share Posted January 26, 2016 If my experience with the HD500 is anything to go by, I don't think so, although I could be wrong. For instance, when I place a Tape Delay (wet) behind a full amp, it craps itself. I always felt a bit of a bummer never being able to put the tape in the FX loop, where it probably won't sound so buzzed out, but still carry the dirt from the pre amp. I would say that the models on the HD500 and Helix react completely differently from each other, so your experience on the HD500 isn't really anything to go by... Personally, I do like the way many effects react after the amp block and before the cab block on the Helix. It's a nice feature. Quote Link to comment Share on other sites More sharing options...
TheDaveDaveDave Posted January 27, 2016 Share Posted January 27, 2016 I always thought it would be behave like this - the effects placed before the amp block in helix would behave the same as I would put them between Guitar and Input of the real amp - the effects placed after the amp block in the helix is routed like I would place them in the effects loop of a real amp Erm, no, not really - at least your second point isn't quite what I'd said. When you put a real effect in a real effects loop, there's usually 1/2 of a 12ax7 (or 12at7) dual triode before the effect, and another 1/2 preamp buffer tube after it, followed by the phase inverter tube and then the power tubes and output transformer. That's a LOT going on post-effect when you use an effects loop, but the biggest part is the cab's high frequency attenuation of anything the effect does. When you place an effect between one of Helix's amp blocks and a cab block, it is after the aforementioned preamp buffer tube, phase inverter, power tubes and output transformer. Usually in the studio you'd have reverb and delays, even modulation effects added after all that AND after the speaker, the mic, the mic pre and maybe the board's EQ. Each of these permutations sounds different - for better or for worse. More commonly it sounds better to have studio effects after the cab and mic, IMHO, and it also sounds more like what we're used to hearing on most recordings, and of course, with the Helix, if we so choose.... Whew - sorry for the long windedness... Cheers! 1 Quote Link to comment Share on other sites More sharing options...
