archisc Posted February 8, 2016 Share Posted February 8, 2016 Is there a sound a difference between vertical vs horizontal position? Quote Link to comment Share on other sites More sharing options...
BucF16 Posted February 9, 2016 Share Posted February 9, 2016 90 degrees... Quote Link to comment Share on other sites More sharing options...
archisc Posted February 9, 2016 Author Share Posted February 9, 2016 I read somewhere the system automatically cut bass in horizontal position... is that true? Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted February 9, 2016 Share Posted February 9, 2016 I think they will automatically go into monitor mode if you turn them on when they are on their side. This can also be done manually but how exactly that affects the EQ'ing I don't recall. That said this can be over-ridden if you don't like them in monitor mode, just use the button on the back to put them back into PA/Reference mode. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted February 9, 2016 Share Posted February 9, 2016 I think they will automatically go into monitor mode if you turn them on when they are on their side. This can also be done manually but how exactly that affects the EQ'ing I don't recall. It's supposed to reduce the exaggerated low-end coupling that sometimes happens when you lay a speaker on the floor. Whether it happens at all, or to what degree probably depends on the floor, and how much bass you're pumping through to begin with... Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted February 9, 2016 Share Posted February 9, 2016 Monitor mode definitely does cut the lower end - whether you want to do this depends on what you are after. I use mine as a monitor but have already cut most of the low end from my guitar to avoid getting muddy with the bass player and drummer :wacko: Paul Hindmarsh when has demoing Helix used a pair of L2m on their sides but in PA Ref mode - I checked because the other thing that Monitor mode does is to sum L+R to mono which isn't what you want if you have two of them. Quote Link to comment Share on other sites More sharing options...
archisc Posted February 9, 2016 Author Share Posted February 9, 2016 Got it.. I think the consensus is that bass is cut only in monitor mode. I was thinking bass is cut regardless... thanks everyone Quote Link to comment Share on other sites More sharing options...
BucF16 Posted February 22, 2016 Share Posted February 22, 2016 I will add that since I've been using the L2's for guitar speakers I think they sound better in PA/Reference but with the speaker on it's side. With the speaker vertical and with the horns dispersion pattern, I get way too much of the high end to my ear. With the speaker horizontal it sounds much better. This is really only an issue on stage with the band and the volume up. Playing at home at more civil volumes I don't really notice a huge difference. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted February 23, 2016 Share Posted February 23, 2016 Paul Hindmarsh when he demoed Helix used a pair of L2m positioned as backline on their sides tilted in the 30deg position but in PA/Reference mode. Quote Link to comment Share on other sites More sharing options...
jeremybnz Posted February 28, 2016 Share Posted February 28, 2016 In monitor position it definitely cuts the low end, quite noticeable at band practice :) Quote Link to comment Share on other sites More sharing options...
glorioso Posted April 28, 2016 Share Posted April 28, 2016 Which mode will sound the most like what I hear through my headphones? I assume PA/Reference Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted April 28, 2016 Share Posted April 28, 2016 It depends on your headphones! Studio Headphones then Reference/PA Consumer Headphones then possibly Playback Floor Monitor has a bass cut to allow for a stage/room resonating in sympathy and boosting the bass levels Keyboard, Acoustic and Electric are for back-line amplification of those specific instruments With a Helix I would always be in Reference/PA Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted April 28, 2016 Share Posted April 28, 2016 Which mode will sound the most like what I hear through my headphones? I assume PA/Reference Your ears are gonna answer that for you...not all headphones are created equal. If you're listening through a pair of "Beats", it's likely adding so much low-end that anything else you plug into will sound tinny and brittle by comparison. Quote Link to comment Share on other sites More sharing options...
BucF16 Posted May 15, 2016 Share Posted May 15, 2016 You can still manually put it back to PA/Reference mode when it's on it's side. If you're just running your guitar through it, I'd use PA/Ref. However a lot of times I'm using it as a monitor for the band with my guitar mixed in, then I usually use monitor. YMMV. Again, I've found that where the tweeter is pointing relative to your ear makes the biggest difference at band volume. Quote Link to comment Share on other sites More sharing options...
Robert_M Posted October 3, 2016 Share Posted October 3, 2016 Using these as monitors is a secondary purpose. They are primarily a PA system with the speakers designed to broadcast high frequency information for a distance. Up close in the vertical position you'll always get an over-emphasized treble component. Quote Link to comment Share on other sites More sharing options...
