MusicGeek Posted February 15, 2016 Share Posted February 15, 2016 Hi, I'm newbie with Helix. Is it possible to assign an equalization to the earphone output, another for the xlr output, and so on. I've seen that there is a global eq, but I don't know if there are specific eq's for the different outputs. Quote Link to comment Share on other sites More sharing options...
duncann Posted February 15, 2016 Share Posted February 15, 2016 There is no static EQs for the purposes specific outputs. To do what you want, it would have to be per patch, by simply putting an EQ before an output. A patch can have more than one output assigned to it. 1 Quote Link to comment Share on other sites More sharing options...
RRMark Posted February 15, 2016 Share Posted February 15, 2016 There is no static EQs for the purposes specific outputs. To do what you want, it would have to be per patch, by simply putting an EQ before an output. A patch can have more than one output assigned to it. As Duncann said. The global eq can be applied to either XLR, 1/4", or both. The headphones can only monitor XLR, or 1/4", or all, no specific headphone only setting. In 'all' it excludes the global eq as this can't be applied to the digital out. I think you can route a maximum of 3 separate outputs in the preset, this does limit block options, 2 outputs is fine, headphones aren't a selectable output in a preset. Quote Link to comment Share on other sites More sharing options...
duncann Posted February 15, 2016 Share Posted February 15, 2016 As Duncann said. The global eq can be applied to either XLR, 1/4", or both. The headphones can only monitor XLR, or 1/4", or all, no specific headphone only setting. In 'all' it excludes the global eq as this can't be applied to the digital out. I think you can route a maximum of 3 separate outputs in the preset, this does limit block options, 2 outputs is fine, headphones aren't a selectable output in a preset. Pretty much what's said here, with the addition of you could have up to four distinct outputs on a preset, and a unique EQ applied to each output, with the output selection options being: 1/4", XLR, Send 1/2, Send 3/4, Digital, USB 1/2, USB 3/4, USB 5/6. 1 Quote Link to comment Share on other sites More sharing options...
MusicGeek Posted February 15, 2016 Author Share Posted February 15, 2016 Thanks. I think that this aproach force us to change every preset individually. Maybe a equalization per output that affects all presets will be a better idea. I think that I will try to create a Ideascale item for this Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted February 15, 2016 Share Posted February 15, 2016 http://line6.ideascale.com/a/dtd/Seperate-global-eq-s-1-4-xlr/804057-23508 Here's one too. Adding headphone, or heck even all outs would be great. Quote Link to comment Share on other sites More sharing options...
aepoc Posted February 15, 2016 Share Posted February 15, 2016 On the EQ topic, I'd love to nail an EQ block that sounds exactly like what I hear out of my Avatar 2x12 with Eminence Legend V12s! :D Quote Link to comment Share on other sites More sharing options...
RRMark Posted February 16, 2016 Share Posted February 16, 2016 On the EQ topic, I'd love to nail an EQ block that sounds exactly like what I hear out of my Avatar 2x12 with Eminence Legend V12s! :D I've been experimenting with this. I set up one preset with an amp block into the output block set to 1/4" into the return of a valve head into my Marshall 1x12. Next to this another preset with identical amp block into the celest1x12 SIM into an eq block to output block set to XLR into an frfr monitor. Get as close as possible with the cab SIM Mic choice/ distance, then bounce between the two presets tweaking and saving the eq. Got pretty close. Also been reading about making my own IR with Voxengo Deconvolver software. Hoping with a condenser Mic at a bit of a distance I might get more of an amp in the room sound. Demo version let's you make 3 IRs then reboot. Also might try making IRs from famous songs. 1 Quote Link to comment Share on other sites More sharing options...
aepoc Posted February 16, 2016 Share Posted February 16, 2016 I've been experimenting with this. I set up one preset with an amp block into the output block set to 1/4" into the return of a valve head into my Marshall 1x12. Next to this another preset with identical amp block into the celest1x12 SIM into an eq block to output block set to XLR into an frfr monitor. Get as close as possible with the cab SIM Mic choice/ distance, then bounce between the two presets tweaking and saving the eq. Got pretty close. Also been reading about making my own IR with Voxengo Deconvolver software. Hoping with a condenser Mic at a bit of a distance I might get more of an amp in the room sound. Demo version let's you make 3 IRs then reboot. Also might try making IRs from famous songs. Interesting. I'll have to try to do the same thing with my cab. I can see it taking a hell of a long time for me though. HAHA. Quote Link to comment Share on other sites More sharing options...
