bull1030 Posted February 17, 2016 Share Posted February 17, 2016 I have it connected through the effects loop on the helix. As it is it works perfectly fine. Im not certain but can I connect a cable to the rockman to be able to switch the channels, like the ext amp port. At least that is what I was thinking. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted February 17, 2016 Share Posted February 17, 2016 I have it connected through the effects loop on the helix. As it is it works perfectly fine. Im not certain but can I connect a cable to the rockman to be able to switch the channels, like the ext amp port. At least that is what I was thinking. That might just work. I am hesitant to try things like that with vintage equipment until L6 gets all the "Ext Amp" issues sorted out. Quote Link to comment Share on other sites More sharing options...
geekpimp Posted February 17, 2016 Share Posted February 17, 2016 yes, the sustainor's bypass, rhythm, and treble boost functions will work with a typical on-off footswitch, so the ext amp will work. cheers, Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted February 17, 2016 Share Posted February 17, 2016 I have it connected through the effects loop on the helix. As it is it works perfectly fine. Im not certain but can I connect a cable to the rockman to be able to switch the channels, like the ext amp port. At least that is what I was thinking. yes, the sustainor's bypass, rhythm, and treble boost functions will work with a typical on-off footswitch, so the ext amp will work. cheers, Geekpimp is a bolder man than I but probably correct! Quote Link to comment Share on other sites More sharing options...
duncann Posted February 17, 2016 Share Posted February 17, 2016 I used to have one these also. Geekpimp is correct. Quote Link to comment Share on other sites More sharing options...
