stevenah Posted February 22, 2016 Share Posted February 22, 2016 I've downloaded the WORKBENCH HD software, connected the DVI cable to the guitar and computer, connected a guitar cable to the guitar and turned the guitar on, but Workbench and the Computer won't connect. Do I need the workbench interface? Do I need to connect to an amp as well? I just want to update my JTV59. Any help? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 22, 2016 Share Posted February 22, 2016 A VDI cable has RJ-45 type connectors on both ends. This will not work if connected to an Ethernet port on your computer. You need to use the Workbench hardware interface, which converts an RJ-45 connection from your JTV to a USB connection to your computer. Alternatively you can use a POD Hd500X or ProX device as the workbench interface. ... And yes, you do need to connect the guitar output to an amp or multiFX device. Workbench HD does not produce audio; your JTV guitar does that. 1 Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted February 22, 2016 Share Posted February 22, 2016 Use the USB interface that came with the guitar. It is designed to connect your guitar to a PC to run Workbench or do an update. Quote Link to comment Share on other sites More sharing options...
Zentorz Posted February 25, 2016 Share Posted February 25, 2016 Thanks. That answered my Q as well Quote Link to comment Share on other sites More sharing options...
dugbug Posted February 28, 2016 Share Posted February 28, 2016 For those that have searched to this thread something you have to always do is make sure you have the battery charged and in your variax as well as an audio jack plugged in, otherwise the guitar will not use the battery and it WILL NOT use usb power. Does not matter if you plug the audio jack into an amp, it just has to be fully inserted into the guitar. Then the variax will talk over vdi-to-usb to your software. I always forget the need to insert 1/4" cable and have a temporary panic :) 1 1 1 Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted February 28, 2016 Share Posted February 28, 2016 One last thing to make sure you do. Turn the Volume Knob up! If it's all they down, the guitar is in sleep mode and it won't talk. Quote Link to comment Share on other sites More sharing options...
DNHurwitz Posted February 25, 2018 Share Posted February 25, 2018 Hi all - I am still troubleshooting this problem and believe I've taken all the proper steps: Variax JTV-59 battery charged, using Variax-supplied USB interface, 1/4" audio cable plugged into the guitar, both green lights on (on USB interface), volume knob up, and Line6 Monkey see both USB interface and Variax just fine. But Workbench HD will not connect. I'm running Sierra 10.12.6 on a 3-year old MacBook Pro. The Variax is brand new. I cannot install older Workbench on this OS. Help?? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 25, 2018 Share Posted February 25, 2018 I'm not familiar with the Mac world but I know that on Windows you would need to install the Line 6 driver. Is there a corresponding Mac component you need? Quote Link to comment Share on other sites More sharing options...
DNHurwitz18 Posted February 26, 2018 Share Posted February 26, 2018 Line 6 drivers are all up to date - that's the Line 6 Monkey interface, which tracks all updates. I'm current on everything. And the other Line 6 software (Monkey) sees the Variax. Just not Workbench HD. Quote Link to comment Share on other sites More sharing options...
djarauta Posted July 11, 2019 Share Posted July 11, 2019 Same problem here, but in windows 10..... any solution? Quote Link to comment Share on other sites More sharing options...
Debets2 Posted August 2, 2019 Share Posted August 2, 2019 I think I may have found the answer. My setup is practically the same as DNHurwitz18, with a Mac Pro running Mavericks. Been scratching my head why Workbench wouldn't see the JTV, until I restarted (again!) and started Workbench as the first application. And voila, there is was. Tested and fiddled around a bit more and discovered that now that WB was seeing the guitar, Monkey couldn't! So apparently only ONE application can connect to the guitar at the same time. Closed WB and started Monkey and yes, it was visible there. Hope this helps anyone wondering about Workbench and the JTV. 1 Quote Link to comment Share on other sites More sharing options...
