jrguitar 1 Posted February 28, 2016 I have a Variax Standard Guitar, I decided to update the firmware with the line 6 USB port provided with the guitar, the update begins normaly but the update finished with an error an the Guitar right now wont turn on the modeling features , I tried to update again but my comouter doesnot see any more the device, also I try the option on Line6 monkey (I DONT SEE MY DEVICE) but the guitar doesnot turn on...what I need to do to flash again the GUITAR... thanks!!! 1 Quote Share this post Link to post Share on other sites
psarkissian 354 Posted February 29, 2016 Check the Knowledge Base on Flash updating. There should be a recently updated document. Quote Share this post Link to post Share on other sites
jrguitar 1 Posted February 29, 2016 Hi, the problem is that the computer won't see the variax after a bad filmware update, my computer with monkey won't detect the variax guitar and I didnot be able to do anything else with monkey software... Quote Share this post Link to post Share on other sites
psarkissian 354 Posted February 29, 2016 http://line6.com/support/page/kb/_/guitars/james-tyler-variax-guitars/variax-reflash-and-software-update-instructions-r103 Quote Share this post Link to post Share on other sites
jrguitar 1 Posted March 1, 2016 thanks for answer i tried those instruction but doesn't work, and the computer won't see the variax guitar on the software updater after an error occurred when I updated the firmware the last time. Iam using the line6 monkey 1.71 with also the latest drivers... also the inside relay of the guitar doesn't click as normally. I try also to use My POD HD500x , but doesn't work. Quote Share this post Link to post Share on other sites
psarkissian 354 Posted March 1, 2016 It will need to serviced. You've gone as far you can. You've logged a ticket, someone from support will respond. Quote Share this post Link to post Share on other sites
ben-chan 0 Posted August 15, 2019 Hi, jrguitar! My Variax Standard also cannot turn on the modeling features after firmware update as you described above. Have you already fix the problem? Quote Share this post Link to post Share on other sites
psarkissian 354 Posted August 15, 2019 Try re-Flashing it again. Quote Share this post Link to post Share on other sites
