Amp+Cab to Amp settings
hideout
I've ran into that problem as well when I wanted to convert an ir.  I haven't found a way to do it.
If its just a cab change, you can turn the "joystick" knob when on page 3 of the Amp+Cab page.  It will change the cab.
Yeah, I was really asking for my brother.  He's created a few patches he likes and then decided to buy some IRs. He was using Amp+Cabs but now with the IRs, he'll to replicate the settings in the Amp+Cabs, ignoring the Cab of course, and reentering them into the new Amp only block. Tedious but I guess that's the way it is.
Can you copy the Amp+Cab's settings onto just an Amp block?  Obviously ignoring the Cab portion of the settings
No. Simply. You can not.
And, fwiw, this is one reason to never every create a patch with an Amp+Cab in it at all. There's no benefit to using it, since you'll never fill every slot. I figured that out a day or so in.
I thought I had seen somewhere a few months ago in the forum that the Amp+Cab combinations had been optimized to use less DSP than a separate amp and cab. Is this not the case?
This is interesting cause I find the Amp+Cab sound completely different than the pre-amp block + cab block. Try it.
Make sure to select the "Amp" block. Amp is the preamp and power section. Preamp is just the models preamp section only - for those who 4 cable and like their own power amp.
Don't know, but I haven't been unable to make patches work separating them. If there's a difference, I'll bet it's very small.
YES!!  YES!!  YES!!
FOUND A COOL FEATURE OF THE EDITOR!!!  sorry had to yell it out.  It saves the setting for the Amp when removing the Cab. (and after further testing, adding a cab too)
Connect to computer open Helix Editor.
1. Select your Amp+Cab block.
2.  Below the Path display just above the sliders on the left, click "amp+cab". (displayed in red)
3.  Select Amp --- Guitar (Bass if Applicable).
4.  Here's the important part.  Double click the SAME, I repeat, SAME model amp as in the Amp+Cab.
All setting in the amp stay as were in the previous setting!   :D
I am using a windows 10 laptop, so not sure about Mac.  I have tested it and I seem to get consistent results.  And if you accidently select the wrong amp and defaults come back, just reselect the patch without saving to recall you prior settings.
  • Upvote 4
YES!!  YES!!  YES!!
+1 Nice tip!
