vcf6 Posted April 2, 2016 Share Posted April 2, 2016 I would recommend backing up your earlier version if possible before updating. I downloaded the update and don't like it for the following reasons: 1) GUI is completely different - way too modern, Ableton? Prefer the effects and amps to look 'real' But more importantly....... 2) You cannot switch effects of by tapping them. You have to select the effect first, then select on/off from new window. So there's no 'stomp' switch on the effects. So that's 2 actions rather than one. Compare with Tonestack where I can turn multiple effects on/off with one press. Apart from the Audio Energy beam there is little difference. I had no problems with the old interface despite using it on an iPad mini and I'm not very good generally with touch screens. Plus point - you can change buffer size inside the app. Quote Link to comment Share on other sites More sharing options...
kmeals9898 Posted April 8, 2016 Share Posted April 8, 2016 They need to do some thing, it's turned into junk. It doesn't work on my IPod, It won't shut down all the way on my IPhone. I have to restart my phone so it doesn't drain the battery. They at least need to respond and let their paying customer know what is going on and what time frame it maybe resolved. Quote Link to comment Share on other sites More sharing options...
jdonato Posted April 8, 2016 Share Posted April 8, 2016 Also: Custom tone.com access is gone. So if you like downloading other user-contributed tones, try to do it before "upgrading". But beware: In my case, I tried or tested the upgrade in two different ways: "upgrading" without user tones, only with the factory ones (clean upgrade), which went OK. BUT upgrading with my favorite downloaded user tones resulted in crashing while opening the app. It would begin the updating/migrating tones process and crash. Every time. Had to delete everything and begin again. And by this I mean, deleting everything "Mobile Pod" from my devices and computer, getting an old copy of version 1.7, downgrade, download EVERY tone again, and try to upgrade to v 2 again, to no avail. And, since you cannot add custom tones after the fact, there is no way to troubleshoot by adding a few tones at a time... So, if you do not want to lose your custom tones, do not try to upgrade for now, or at least, backup them to your computer with something like PhoneView or other utility before trying. And keep a copy of version 1.7 handy. And, if I remember correctly, there is a "Share" button! So Line 6 wants me to share my tones, but there is no way to benefit from the sharing??? I contacted Line 6 about the loss of customtone.com (hoping that it was an omission, that it would come back) but received an answer that confirmed worst case scenario. It's gone, at least for now. Hopefully they change their minds. Most other amp sim apps have some kind of sharing enabled. On the interface issue, I really like the way things are distributed now and how I can access tones in a kind-of split window. I would compromise: keep things distributed on screen as they are, bring back the "real-ish" looking amps and effects. I concur with OP about having the possibility of switching effects by tapping. Quote Link to comment Share on other sites More sharing options...
TexLefty65 Posted April 9, 2016 Share Posted April 9, 2016 They need to do some thing, it's turned into junk. It doesn't work on my IPod, It won't shut down all the way on my IPhone. I have to restart my phone so it doesn't drain the battery. They at least need to respond and let their paying customer know what is going on and what time frame it maybe resolved. Actually, there is a switch in the Mobile POD 2's Settings screen called "Run app in background". This is on by default, but if you turn it to Off, then whenever you close the app, it exits all the way. I think you need to also disconnect your audio interface too though when not using it - it looks like my iPhone always pings my interface every so often, which probably also drains the battery some, but apparently that's an iOS thing since it does that whether Mobile POD (or any music app) is running or not. Quote Link to comment Share on other sites More sharing options...
kmeals9898 Posted April 9, 2016 Share Posted April 9, 2016 Thanks, that took care of the app still running on exit. I did know about the Sonic Port still running even when the apps are closed out due to it running as an sound interface. So far no luck on the IPod, 20 reinstalls later and it will still crash when opened every time. I'd prefer using the IPod over the phone so the phone battery is charged for when I go to work. Quote Link to comment Share on other sites More sharing options...
dalvow Posted April 14, 2016 Share Posted April 14, 2016 Same problem on my iPhone, opened only without my tones. But on my iPad I opened mobile pod in cubasis. It took a while and then migrated all my usertones. I heard from the support, that there will come an update. We are all beta users ;-( My question: I want to go back to 1.7 and does anyone have the .ipa on his computer? I updated to fast and only have the version 2.0 in iTunes. Line 6 isn't cooperative and do not want to go back to the older version, I can not get ist. Is there anyone willing to send me the file? info@a-t-design.eu Many thanks in advance Achim Quote Link to comment Share on other sites More sharing options...
vcf6 Posted April 16, 2016 Author Share Posted April 16, 2016 Yes I second that - anyone who hasn't updated yet will still have 1.7 ipa on their computer. I'm hoping if I can get hold of a copy I can replace V2.0 - maybe Line 6 can send me a copy? vcf2@tesco.net - just hoping :) Quote Link to comment Share on other sites More sharing options...
ArthurAlan Posted November 16, 2017 Share Posted November 16, 2017 Yes I agree. The current app is rubbish. We,Line 6 paying customers deserve better or at least the ability to revert back to the original software. Quote Link to comment Share on other sites More sharing options...
Pacemaker1000 Posted February 28, 2018 Share Posted February 28, 2018 Wow! Did a search for the old 1.7 and can’t believe Line 6 took such a massive step backwards! It looks like everything I want in a sim. Better looking than 2.0 and more importantly the ability to download custom tones. Bring it back, or at least the latter, and I’ll buy it! Quote Link to comment Share on other sites More sharing options...
