nippyjun Posted April 21, 2016 Share Posted April 21, 2016 Hi, it seems that every time I use the tuner it's output is default set to mute. Is there a way to save my preference to have the output set to multi? Thanks. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 21, 2016 Share Posted April 21, 2016 Hi, it seems that every time I use the tuner it's output is default set to mute. Is there a way to save my preference to have the output set to multi? Thanks. Hold down the Tap footswitch until the Tuner comes up. You will see a "Tuner Out" parameter. Set this to "Multi" instead of "Mute". The tuner parameter options are global and will "stick" from one preset to the next once you change them. See page 31 of the manual if you want more details. Quote Link to comment Share on other sites More sharing options...
Dshow Posted April 22, 2016 Share Posted April 22, 2016 Hold down the Tap footswitch until the Tuner comes up. You will see a "Tuner Out" parameter. Set this to "Multi" instead of "Mute". The tuner parameter options are global and will "stick" from one preset to the next once you change them. See page 31 of the manual if you want more details. If you restart Helix it goes back to Mute. The settting is not saved - at least on my Helix. I wanted request this for a long time: @nippyjun Did you open an Idea on Ideascale? Quote Link to comment Share on other sites More sharing options...
nippyjun Posted April 22, 2016 Author Share Posted April 22, 2016 I just opened the idea on ideascale 1 Quote Link to comment Share on other sites More sharing options...
Dshow Posted April 22, 2016 Share Posted April 22, 2016 I just opened the idea on ideascale Thanks - voted! Quote Link to comment Share on other sites More sharing options...
droeber Posted April 22, 2016 Share Posted April 22, 2016 While we're requesting tuner features, I'd love to have the tuner muted through specific outputs and not others. My use case is XLR on Mute, but Headphones not, but I'm sure others have more interesting use cases. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 22, 2016 Share Posted April 22, 2016 If you restart Helix it goes back to Mute. The settting is not saved - at least on my Helix. I wanted request this for a long time: @nippyjun Did you open an Idea on Ideascale? You are absolutely right! I would say this almost qualifies as a bug rather than a feature request. Changes to the "Reference" or the "Offset" parameter do stick after a restart but the "Tuner Out" parameter does not. That makes the behavior inconsistent. All your tuner parameter selections should be retained after restart. Btw, I am on Firmware ver. 1.10.0. Quote Link to comment Share on other sites More sharing options...
nippyjun Posted April 22, 2016 Author Share Posted April 22, 2016 You are absolutely right! I would say this almost qualifies as a bug rather than a feature request. Changes to the "Reference" or the "Offset" parameter do stick after a restart but the "Tuner Out" parameter does not. That makes the behavior inconsistent. All your parameter selections should be retained after restart. Btw, I am on Firmware ver. 1.10.0. Please vote on this on ideascale. thanks. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 22, 2016 Share Posted April 22, 2016 I just opened the idea on ideascale Voted and here is the link for nippyjun's idea to retain the Tuner settings properly. http://line6.ideascale.com/a/dtd/Tuner-output-setting-needs-to-be-remembered/818690-23508 Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted April 22, 2016 Share Posted April 22, 2016 It's definitely a bug. We'll have it fixed in the next rev. 2 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 22, 2016 Share Posted April 22, 2016 Hi, it seems that every time I use the tuner it's output is default set to mute. Is there a way to save my preference to have the output set to multi? Thanks. It's definitely a bug. We'll have it fixed in the next rev. Thanks DI! Quote Link to comment Share on other sites More sharing options...
Dshow Posted April 22, 2016 Share Posted April 22, 2016 Thanks! Quote Link to comment Share on other sites More sharing options...
