parker1963 Posted May 16, 2016 Share Posted May 16, 2016 Just a little heads up on the latest update on the Helix, it changes your input settings, guitar pad is turned off and it defaults to 1Meg input impedance :(, not good enough Line 6, this is the sort of malarky I expect from iTunes Quote Link to comment Share on other sites More sharing options...
maxnew40 Posted May 16, 2016 Share Posted May 16, 2016 Did it reset all of the globals? I found that previous updates reset all the global parameters on my unit. -Max Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted May 16, 2016 Share Posted May 16, 2016 Just a little heads up on the latest update on the Helix, it changes your input settings, guitar pad is turned off and it defaults to 1Meg input impedance :(, not good enough Line 6, this is the sort of malarky I expect from iTunes Did you do the all reset function after finishing? If so, that's what would happen. Need to check all your globals after an update anyhow. Quote Link to comment Share on other sites More sharing options...
hideout Posted May 16, 2016 Share Posted May 16, 2016 I don't think it's a biggie if it's just the Global Settings. It'd be a different story if it was affecting all the presets in a weird way. Quote Link to comment Share on other sites More sharing options...
jeebster Posted May 16, 2016 Share Posted May 16, 2016 Just a little heads up on the latest update on the Helix, it changes your input settings, guitar pad is turned off and it defaults to 1Meg input impedance :(, not good enough Line 6, this is the sort of malarky I expect from iTunes Could you or anyone else expand upon why this is a big issue? Is this dealing with unwanted signal boosting? I have the same values in my Global Settings and the output sounds pretty nice to my ears. Quote Link to comment Share on other sites More sharing options...
