FacemanJoe Posted May 19, 2016 Share Posted May 19, 2016 44.1hz, 48hz, 88.2hz or 96hz?Thanks! Joe Quote Link to comment Share on other sites More sharing options...
duncann Posted May 19, 2016 Share Posted May 19, 2016 I believe the built in cabs (IRs) are 16-bit 48kHz. I use 24-bit 48kHz for the little I use. One of them, Taylor 314ce-Earthworks, is 32-bit 48kHz. No problems with either of those formats. Ultimately, it's not going to make any difference. You could leave things to chance by blindly picking one of the four out of hat. Quote Link to comment Share on other sites More sharing options...
roscoe5 Posted May 19, 2016 Share Posted May 19, 2016 From the Helix manual p.28 Helix can load and store up to 128 IRs at a time. 48kHz, mono, .WAV type IRs are supported. However, I believe Helix converts all IR's to 48kHz on Import. So I seem to be able to use any sample rate 48kHz or higher. Quote Link to comment Share on other sites More sharing options...
FacemanJoe Posted May 20, 2016 Author Share Posted May 20, 2016 Super. Thank you Quote Link to comment Share on other sites More sharing options...
cabIReu Posted May 20, 2016 Share Posted May 20, 2016 Helix converts to 48kHz / 16bit / 2048samples length ... Quote Link to comment Share on other sites More sharing options...
