mtsprout 0 Posted August 17, 2013 Hi all, i know that this has been a topic that has been discussed ad infinitum around here, but I seem to be in a different quandary. I flashed the firmware on my HD500 today - successfully, according to the Monkey - and now I am sometimes stuck in a reboot loop. I can play through the POD for a while, and it's fine, then after a few minutes, it starts into a reboot loop. Sometimes I can play for 15 minutes, then a reboot, then 10 minutes, then we're rebooting again. I've flashed firmware from 2.02 to 2.10 and back again, and the problem persists. I've done the left arrow hardware reset, I've done the right arrow reset, I've done the down arrow reset. I've flashed and re-flashed, and I can seem to escape the boot loop. I thought I might have a heat issue, or something like that, but if I leave it plugged in in safe mode, it stays on no problem. I have been fighting this for hours and hours and hours and I am at the end of my rope. Any help greatly appreciated. Thanks! Quote Share this post Link to post Share on other sites
mtsprout 0 Posted August 17, 2013 It also seems like it can be triggered by trying to add an amplifier in a new chain, or occasionally, just by pushing signal through my guitar. Quote Share this post Link to post Share on other sites
silverhead 8,817 Posted August 18, 2013 Does this happen only when using HD500 Edit, only when using the HD500 alone, or in both cases? Quote Share this post Link to post Share on other sites
mtsprout 0 Posted August 18, 2013 I haven't tried it when using HD500 Edit; only alone. With some of the horror stories about the USB port and whatnot, I leave it unconnected unless flashing firmware. Quote Share this post Link to post Share on other sites
silverhead 8,817 Posted August 18, 2013 If possible, try a different (but identical spec-wise!) power supply. If there's a Line 6 dealer nearby perhaps you could borrow one for a while, either in their store or on a refundable deposit basis to take home. Quote Share this post Link to post Share on other sites
mtsprout 0 Posted August 18, 2013 I was thinking about a PS issue, but it seems like that would have manifested itself prior to the upgrade. Still worth a try, though, and I'll see what I can get done. Thanks for the input. Quote Share this post Link to post Share on other sites
mtsprout 0 Posted August 28, 2013 SOLUTION: It was the power supply. As it turns out, I was given a 9VAC power supply, not the correct 9V DC P/S. Still odd why it had been working, but it was a red herring, as it turns out. Quote Share this post Link to post Share on other sites
scottyo78 29 Posted August 28, 2013 Please tell us you bought your HD500 "used". :o I'd hate to hear that you got the wrong power supply inside a "brand new" unit. :blink: Quote Share this post Link to post Share on other sites
mtsprout 0 Posted August 28, 2013 Yeah, it was used. :) Quote Share this post Link to post Share on other sites
silverhead 8,817 Posted August 28, 2013 You're lucky - it could easily have fried your device. Quote Share this post Link to post Share on other sites
schlottdog 1 Posted November 13, 2013 I am having the same issue. I am about to throw out my HD500. I have had the XT Live for 8 years....never ONE problem at all. I have had the HD500 since July.....probably about 30 reboot loops. I am afraid to gig with it. The power supply did go bad and I went to Guitar Center and bought a "Line 6" brand power supply. Still loops....arrrgghhhhh. I have flashed to 2.02 and then to 2.10....it still does it. I do admit, it happens only with the USB plugged in....I will try again this evening without the USB plugged in. Opened asupport ticket with support. Hopefully they won't say "Send it in and we will charge you $200 to fix it". I only paid $370 used (100% presitne condition...in fact, looks like it was never out of the box). Quote Share this post Link to post Share on other sites
toneman2121 598 Posted November 13, 2013 I am having the same issue. I am about to throw out my HD500. I have had the XT Live for 8 years....never ONE problem at all. I have had the HD500 since July.....probably about 30 reboot loops. I am afraid to gig with it. The power supply did go bad and I went to Guitar Center and bought a "Line 6" brand power supply. Still loops....arrrgghhhhh. I have flashed to 2.02 and then to 2.10....it still does it. I do admit, it happens only with the USB plugged in....I will try again this evening without the USB plugged in. Opened asupport ticket with support. Hopefully they won't say "Send it in and we will charge you $200 to fix it". I only paid $370 used (100% presitne condition...in fact, looks like it was never out of the box). do a global reset and cal the pedal Quote Share this post Link to post Share on other sites
