amsdenj Posted May 31, 2016 Share Posted May 31, 2016 I tried making a couple of my own speaker IR a couple of weeks ago. These are made in my garage, so there could be some additional "color". I used some blankets in front of and behind the speakers to minimize reflections and reduce the noise. But its not an ideal environment. I used just two mics, an old SM57 and a AT4047 condenser mic. they are both positioned at cap-edge and about 1.5" from the front of the cabinet grill. That was convenient and easy to setup, and tends to be what I typically pick. I'd use a ribbon mic closer if I had one though. The first cabinet is an old Fender Bassman 2x12 cabinet with 2 Celestion G12-65 speakers I recently installed. That cabinet has an open back I made to slightly reduce the bass, and provide better room sound for the drummer. The second cabinet is my friend Nate's early 60's Tremolux which has a closed back, un-ported cabinet. It has the original Oxford 10K5 and is really a wonderful sounding amp and cabinet. I love the bias tremolo!. Anyway give these a try if you like. They sound pretty good. You can really hear the difference between the open and closed back cabinets. G12-65 AT4047 cap-edge 1.5 in.wav G12-65 SM57 cap-edge 1 in.wav Oxford 10K5 AT4047 cap-edge 1.5 in.wav Oxford 10K5 SM57 cap-edge 1in.wav 1 1 Quote Link to comment Share on other sites More sharing options...
ur2funky Posted June 1, 2016 Share Posted June 1, 2016 Thanks! I look forward to trying these! Quote Link to comment Share on other sites More sharing options...
roscoe5 Posted June 1, 2016 Share Posted June 1, 2016 Cool! Thanks! I'll try them out tomorrow. I think from your ither threads you used Logic for some acoustic IRs. Where these made with Logic's Impulse Response Utility? Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted June 1, 2016 Share Posted June 1, 2016 Thanks for taking the time. I really like these. I got to play with them for about half an hour tonight and, so far, I really like the way they sound with the Soldano clean channel, the Jazz Rivet, the Fender Twin and the Fender Deluxe. Quote Link to comment Share on other sites More sharing options...
pinoy1 Posted June 1, 2016 Share Posted June 1, 2016 I tried making a couple of my own speaker IR a couple of weeks ago. These are made in my garage, so there could be some additional "color". I used some blankets in front of and behind the speakers to minimize reflections and reduce the noise. But its not an ideal environment. I used just two mics, an old SM57 and a AT4047 condenser mic. they are both positioned at cap-edge and about 1.5" from the front of the cabinet grill. That was convenient and easy to setup, and tends to be what I typically pick. I'd use a ribbon mic closer if I had one though. The first cabinet is an old Fender Bassman 2x12 cabinet with 2 Celestion G12-65 speakers I recently installed. That cabinet has an open back I made to slightly reduce the bass, and provide better room sound for the drummer. The second cabinet is my friend Nate's early 60's Tremolux which has a closed back, un-ported cabinet. It has the original Oxford 10K5 and is really a wonderful sounding amp and cabinet. I love the bias tremolo!. Anyway give these a try if you like. They sound pretty good. You can really hear the difference between the open and closed back cabinets. Thanks for sharing, amsdenj! I'll try them when I get my Helix next month. Quote Link to comment Share on other sites More sharing options...
