Sign in to follow this
Jos_K
What is Duty Cycle and how to sync effects
Can anybody enlighten me on what the Duty Cycle parameter does?
Also, if I wanted to use the same effect twice on separate paths, but I want them to be in sync, a Tremolo for instance. How can I do it? Because right now, if you insert the same effect, with the same parameter settings (e.g. via copy/paste block), they're not synced.
Thanks,
Jos
Bump... Yeah, what's duty cycle?
Are they out of sync if you use tap tempo options?
Duty cycle is the percentage of time a signal is on (compared to off). So the higher the duty cycle setting, the longer the pulse.
