Smashcraaft Posted July 18, 2016 Share Posted July 18, 2016 Hi. When I record my Variax 600 in Cubase 8 AI, it leads to a gap at the beginning (like an enormous latency). I am using the POD HD500x which is USB-connected to an iMac. If I use a regular guitar everything is correct. The recording starts right at the beginning and listening to the live-tone and tempo-click everything sounds okay. But when the recording ends there is a gap of nearly 1 second since the tone starts and it ends with the same (here as an overlap). Any ideas? I will try to reproduce this behavior in Audacity later… EDIT: Don't know how to get rid of latency using Audacity. So, no way to reproduce the problem :( Quote Link to comment Share on other sites More sharing options...
eenymason Posted July 19, 2016 Share Posted July 19, 2016 Hi. When I record my Variax 600 in Cubase 8 AI, it leads to a gap at the beginning (like an enormous latency). I am using the POD HD500x which is USB-connected to an iMac. If I use a regular guitar everything is correct. The recording starts right at the beginning and listening to the live-tone and tempo-click everything sounds okay. But when the recording ends there is a gap of nearly 1 second since the tone starts and it ends with the same (here as an overlap). Any ideas? I will try to reproduce this behavior in Audacity later… EDIT: Don't know how to get rid of latency using Audacity. So, no way to reproduce the problem :( SO firstly are you using the HD500 as the soundcard? I guess it must be annoying, but if there's no problem with latency during recording, couldn't you simply move the file once recorded, into it's correct position? 1 Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted July 19, 2016 Author Share Posted July 19, 2016 SO firstly are you using the HD500 as the soundcard? I guess it must be annoying, but if there's no problem with latency during recording, couldn't you simply move the file once recorded, into it's correct position? Yes, I am using the HD500x as the soundcard and the problem only occoures using the Variax. The recording of my Ibanez is 100 % right in time, although it is recorded also using the HD500x. Moving files into position is of course possible, but nothing I want to do until the rest of my days ;) Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted July 22, 2016 Author Share Posted July 22, 2016 I don't know what exactly was the failure but today it worked. I strongly suspect an inpropper USB-connection because the last time I had some sync issues with HD Edit too. At the same time I reconnected all real and digital in- and outputs, so those could have been also the reason. Thank you for your time, eenymason I habe voted you +1 Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted July 22, 2016 Author Share Posted July 22, 2016 The gap appeared again but I was able to fix the problem. After choosing a patch with a lot of fx-blocks I had to switch the ASIO-device to "None" on my Mac, running Cubase 8 (and then switch back again to the HD500x ASIO) to get rid of the recording-delay. Seems to be an ASIO/USB issue. Solved B) 1 Quote Link to comment Share on other sites More sharing options...
