Relay G10 flashes red in charger
MitchellBergen
  • 8 months later...
I just had the same problem with my third G10. The first two had the same problem and Sweetwater replaced them. I am using active basses, and after read the problems others are having there seems to be some problems with active instruments.
  • 10 months later...
Apparently un resolved.  I've updated firmware to 1.04 and got the same symptom.  The transmitter (as far as I can tell) charges O.K. it just doesn't flash the right color (red instead of green).  Will try extended test to see if it really fully charges.
  • 1 month later...
Had this happen only after I started using a cheaper, short usb power supply cable.  Switched a higher quality cable that came with a gaming headset and the red light stops.  Maybe it means that it can't send enough current to adequately charge the transmitter?
Thanks for posting your resolution. As you have discovered, not all USB cables are equal!
The G10 Transmitter's charging current need is very low. I tested mine when I first got them and it was well below the recommendation of a using a standard USB 5v 1Amp charger. If I recollect correctly, the charging current was around 350 milliamps. As a result, I also use any one of several USB rechargeable lithium battery packs with my G10 system and have not had any problems charging, nor powering the receiver base unit. The accessory Line 6 G10 USB Charging Cable is a very handy accessory!
