benifin Posted September 2, 2016 Share Posted September 2, 2016 Hi all As I understand it, FW 2.0.1 does not allow for Auto-Engage / Auto Dis-Engage of the WAH on its movement and stoppage ..... however .... I was wondering, can the WAH in FW 2.0.1 be configured so that it is Auto-OFF @ Heel / Toe ? For example ..... the usual WAH Pedal CC Calibration Range is 0 <-> 127 ..... so instead of this .... => with FW 2.0.1 can the WAH Pedal Active Calibration range be set to [say] 05 <-> 122 so that WAH CC 0 <-> 04 is WAH OFF at Heel -and- CC 123 <-> 127 is WAH OFF at TOE ? Hoping the above makes sense. Ben 1 Quote Link to comment Share on other sites More sharing options...
spikey Posted September 2, 2016 Share Posted September 2, 2016 Here are my old settings for "heel down wah off". Im using a Mission Helix SP1-L6 pedal, but that shouldnt matter as these settings should work with any good foot controller. Feel free to adjust your own settings. I have since adjusted the Maximum value (toe down) on the high freq to 1.3 Khz, and to my ears its better now. The point is, at heel down the percentage of the wah go's to zero, and its now shut off, (tone go's back to original without wah on) and the moment you rock it forward the Wah is back on. Wah settings 1 Quote Link to comment Share on other sites More sharing options...
benifin Posted September 3, 2016 Author Share Posted September 3, 2016 Here are my old settings for "heel down wah off". Im using a Mission Helix SP1-L6 pedal, but that shouldnt matter as these settings should work with any good foot controller. Feel free to adjust your own settings. I have since adjusted the Maximum value (toe down) on the high freq to 1.3 Khz, and to my ears its better now. The point is, at heel down the percentage of the wah go's to zero, and its now shut off, (tone go's back to original without wah on) and the moment you rock it forward the Wah is back on. Wah settings Many thanks - so just to be clear [ from my end - Im a bit slow at these sorts of things :) ] ..... the above can be done with the current FW 2.0.1 ? Ben Quote Link to comment Share on other sites More sharing options...
spikey Posted September 3, 2016 Share Posted September 3, 2016 Well I am running 2.0.1, so yes it should all work fine. :) Quote Link to comment Share on other sites More sharing options...
benifin Posted September 4, 2016 Author Share Posted September 4, 2016 Thanks spikey :) Last question .... I presume then that there is no way to set up and configure just one single WAH preset that can have off-at-heel and off-at-toe in the same single preset ? Ben Quote Link to comment Share on other sites More sharing options...
spikey Posted September 4, 2016 Share Posted September 4, 2016 Ive not done that yet Ben, so not sure...But there are a lot of very talented Helix "patch tweekers" around here that might be able to help! Quote Link to comment Share on other sites More sharing options...
tagmusenmagnus1 Posted September 4, 2016 Share Posted September 4, 2016 Here are my old settings for "heel down wah off". Im using a Mission Helix SP1-L6 pedal, but that shouldnt matter as these settings should work with any good foot controller. Feel free to adjust your own settings. I have since adjusted the Maximum value (toe down) on the high freq to 1.3 Khz, and to my ears its better now. The point is, at heel down the percentage of the wah go's to zero, and its now shut off, (tone go's back to original without wah on) and the moment you rock it forward the Wah is back on. Wah settings what ? how have you done this without the mix being very low when the EXP is near the heal position ? Quote Link to comment Share on other sites More sharing options...
spikey Posted September 5, 2016 Share Posted September 5, 2016 I see your point Tag but I don't have any low volume issues on the low (heel down) side. As it fades the normal tones (non wah) come back in. Try it and see if you like it. :) Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted September 5, 2016 Share Posted September 5, 2016 what ? how have you done this without the mix being very low when the EXP is near the heal position ? I literally just tried this out on a Helix patch one minute ago, and this wah trick is super sweet, thanks Spikey!! And yes, it does 'fade out' the mix of the wah effect as the pedal travels towards the heel, so you can lose some of that weird low end lwo mid frequency muddy flutter that the wah would normally do in that position. For me, I never like that low end of the wah travel anyway, so this is perfect; since I prefer it for high and upper/central mid effect; and it sure makes using the wah easier on the fly! I think the way to go would be test these setting with a few of your 'go to' wah models, and see how it impacts them, as opposed to without. Make a duplicate wah block, and set one to just use the 'regular' settings, and the other to use these settings. I've got this on the Chrome custom, sounds fantastic! Quote Link to comment Share on other sites More sharing options...
spikey Posted September 5, 2016 Share Posted September 5, 2016 Thanks Colonel for the kind words ! For me the loss on the low end "wah" tone is so minimal because kinda it fades back to normal. I don't know how else to describe it, but this works well for me until we get a real "heel-down wah-off" fix/setting like Fractal has in the Axe FX II. Quote Link to comment Share on other sites More sharing options...
glorioso Posted December 15, 2017 Share Posted December 15, 2017 I literally just tried this out on a Helix patch one minute ago, and this wah trick is super sweet, thanks Spikey!! And yes, it does 'fade out' the mix of the wah effect as the pedal travels towards the heel, so you can lose some of that weird low end lwo mid frequency muddy flutter that the wah would normally do in that position. For me, I never like that low end of the wah travel anyway, so this is perfect; since I prefer it for high and upper/central mid effect; and it sure makes using the wah easier on the fly! I think the way to go would be test these setting with a few of your 'go to' wah models, and see how it impacts them, as opposed to without. Make a duplicate wah block, and set one to just use the 'regular' settings, and the other to use these settings. I've got this on the Chrome custom, sounds fantastic! Can you guys post on customtone? I am trying to accomplish the heel down thing right now and it doesn't come easy to me. Quote Link to comment Share on other sites More sharing options...
