ncockerill Posted September 9, 2016 Share Posted September 9, 2016 Hey folks!!! Just downloaded a great patch. Only problem for me is how the Snapshots are assigned to the footswitches. Quick explanation. I have a very specific way I build all my presets. That is, I use 4 snapshots (numbered 1-4) across the bottom row of footswitches (and then stomps on the upper row). They are always set up like this: Snapshot 1 --> Clean Snapshot 2 --> BreakUp Snapshot 3 --> Crunch Snapshot 4 --> Lead So, my snapshots get more aggressive with more gain, delay, etc from left to right. This new patch I downloaded is really great, but it’s actually built in reverse of my standard logic. That is: Snapshot 1 --> Lead Snapshot 2 --> Crunch Snapshot 3 --> BreakUp Snapshot 4 --> Clean How can I reassign (essentially re-order) the snapshots in this new patch to fit my paradigm? Some way to use unused snapshots 5-8 as a placeholder during reassignment? 1 Quote Link to comment Share on other sites More sharing options...
Verne-Bunsen Posted September 10, 2016 Share Posted September 10, 2016 Many times I've pondered this, never have figured it out. Good question and I hope someone has a good answer! Quote Link to comment Share on other sites More sharing options...
zooey Posted September 10, 2016 Share Posted September 10, 2016 Touch, don't press, any two snapshot footswitches, and Helix will offer to swap them. 1 2 1 Quote Link to comment Share on other sites More sharing options...
davidb7170 Posted September 10, 2016 Share Posted September 10, 2016 You can swap and copy snapshots with touch and hold procedure (at least on the floor Helix). It's in the manual, I believe. I've done it many times. Dave Quote Link to comment Share on other sites More sharing options...
ncockerill Posted September 10, 2016 Author Share Posted September 10, 2016 Thanks!!! OMG -- I've used that exact procedure a lot to swap footswitch assignments on individual effect blocks, but it never dawned on me to try it with snapshots. It works, And I.......am a dummy. Quote Link to comment Share on other sites More sharing options...
zooey Posted September 10, 2016 Share Posted September 10, 2016 You're not a dummy. Helix is just unexpectedly smart sometimes, the kind of smart that makes you say, oh yeah, now that I think about it, it makes sense it'd do that. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted September 10, 2016 Share Posted September 10, 2016 ... How can I reassign (essentially re-order) the snapshots in this new patch to fit my paradigm? Some way to use unused snapshots 5-8 as a placeholder during reassignment? If you left-click on the camera icon in the top left corner of the Editor it will allow you to copy a snapshot, select the snapshot number you want to copy to in the pulldown menu to the right and then go back to the camera icon to paste. So you could use 5-8 or any unused snapshot location as placeholders to move the ones you want to rearrange using the Editor. I don't know of any way to directly swap using the Editor however and there is no reference to it in the "Helix Application Pilot's Guide". The simplest way to swap right now does appear to be the simultaneous touch on the Helix footswitches. Quote Link to comment Share on other sites More sharing options...
ldp645 Posted February 24, 2018 Share Posted February 24, 2018 Touch, don't press, any two snapshot footswitches, and Helix will offer to swap them. Thanks, that sorted out my problem too! Quote Link to comment Share on other sites More sharing options...
hrse4fun1 Posted July 19, 2019 Share Posted July 19, 2019 when in snapshot mode on the controller, lightly touch 2 footswitches to swap. ie 4 to 1, 5 to 1. then resave the preset to another slot and the default preset will be what you switched it to Quote Link to comment Share on other sites More sharing options...
hillbilly92 Posted November 30, 2022 Share Posted November 30, 2022 How do I copy one snapshot from one patch to another patch to put into an empty snapshot block? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted December 2, 2022 Share Posted December 2, 2022 On 11/30/2022 at 1:09 PM, hillbilly92 said: How do I copy one snapshot from one patch to another patch to put into an empty snapshot block? If you are talking about copying a snapshot from one preset to another, you can't do that. The blocks may be, and frequently are, different from preset to preset so that action is simply disallowed. Even if the target preset has exactly the same blocks. 1 Quote Link to comment Share on other sites More sharing options...
