metalkrapo Posted October 7, 2016 Share Posted October 7, 2016 Hey all, Is there any way I can add a bass line by adding a harmony an octave lower, that applies only to the low E string? I have a JTV if that helps. Thanks! Quote Link to comment Share on other sites More sharing options...
Ka5par Posted October 7, 2016 Share Posted October 7, 2016 With a hex pickup or Variax it's probably possible. Quote Link to comment Share on other sites More sharing options...
CBTL Posted October 7, 2016 Share Posted October 7, 2016 I don't believe you can do it as a harmony on a single string through the helix! Maybe in work bench you could fiddle about with a twelve string setting and have a lower octive as opposed to a higher octive on the 6th string? You would have to adjust the cent to 0 and the string mix so there the same volume. With all the other strings you may be able to silence the extra "fake" string. Or I could be completely wrong 🤔 Quote Link to comment Share on other sites More sharing options...
radatats Posted October 7, 2016 Share Posted October 7, 2016 you could do that with the Helix and JTV but its complicated. - You would set up one path with input set to Variax mags for your regular guitar tone. - Make a second path with input set to Variax only for the bass line. You have options for the second path: - Force the Variax low E string tuning down an octave in the Helix Input Block and set up a duplicate path with amps and FX. Might work OK. - Set up a Custom Model in Workbench HD where the only string that is active is the low E tuned down an octave. Add your bass amp/cab to that path and it should be OK. Quote Link to comment Share on other sites More sharing options...
metalkrapo Posted October 9, 2016 Author Share Posted October 9, 2016 Nice ideas, thanks! Quote Link to comment Share on other sites More sharing options...
