Anyone else using Pitch Echo as a "Mimiq"?
steevo1977
Quite an interesting little easter egg this, give it a shot.
Pitch at zero
Cents +/- around 1.5 to give a variance
20-30ms delay
20% feedback
Adjust mix and Spread to suit (I had mix at 30-40% and spread around 50%)
I tried the mono one and stereo one before the amp but the best results came from placing it after the IR/Cab or between the Amp and IR/Cab
I did try multiple pitch echo blocks with slightly different configs in tandem however not sure I appreciated the outcome quite the same.
Obviously this isn't the same as a Mimiq pedal but it's similar and WAY better than the HAAS style effect of using LR  panning and a 20-30ms digital delay.
  • Upvote 2
Pitch at zero
20-30ms delay
20% feedback
Thanks! That sounds great and is now part of my lead snapshot. :)
I've tried to recreate that in Helix and hit a limit on CPU...maybe you are on to something!
 I got pretty close with my Boss GT10. I can get close on the intro but making a patch with the other lead components is where it gets weird. There is a good starting block in a patch on Customtone.
Maybe buy a second Helix to run along side the other one? :D
Is spread only on the stereo version ?
Must be, I didn't see a "spread" parameter and I'm running in Mono
Makes sense...
I don’t see any »spread«-parameter in Pitch Echo (Stereo Version) at all. Instead I see a »scale«-parameter. Just to make sure …
Sorry all, yes scale is the correct term and its on the stereo model. I R IDIOT!
Cheers ;)
