markus506 Posted November 24, 2016 Share Posted November 24, 2016 So, I posted a bug in the bug thread, regarding having 8 snapshots, and changing the LED footswitch rings to different colors. When I change the display settings for the rings to 'off/bright' from 'dim/bright' the bottom 4 snapshot rings go out (if none are active) but the top 4 stay dim (none are active). I made a brand new patch as well, and I get the same results. I had submitted a ticket, but I got a response that they were not able to reproduce the issue. Note that in stomp mode, the 'off/bright' setting works fine, and all 10 of the stomp switches I use will go out (if none are active). I'm a bit stumped by this, and was hoping someone could take a minute to either confirm or refute my findings. Thanks, Mark Quote Link to comment Share on other sites More sharing options...
duncann Posted November 24, 2016 Share Posted November 24, 2016 Regardless of the dim/bright of off/bright setting, snapshot leds are always off, except for the one which is selected. At least that's how it works on mine. Quote Link to comment Share on other sites More sharing options...
markus506 Posted November 24, 2016 Author Share Posted November 24, 2016 Regardless of the dim/bright of off/bright setting, snapshot leds are always off, except for the one which is selected. At least that's how it works on mine. There is a new setting in 2.10 that allows you to set the switch LED ring colors similar to stomp mode. Quote Link to comment Share on other sites More sharing options...
duncann Posted November 24, 2016 Share Posted November 24, 2016 There is a new setting in 2.10 that allows you to set the switch LED ring colors similar to stomp mode. Ok. I see the new feature now. And I can confirm the behavior you observed. Bottom row works fine with the off/dim setting, but the top row doesn't. Quote Link to comment Share on other sites More sharing options...
patrick_g_nelson Posted November 24, 2016 Share Posted November 24, 2016 Yes, I was just about to post on the forum about this but found this post. I can confirm that if you set the buttons/switches to 8 snapshots, off/bright for the LED Ring brightness and then go in and resave a different color for each switch you will get the bottom row off and then the top row dimmed to whatever color you set it to. If you change them all back to auto they will all be off/bright as expected. Seems like a pretty simple bug to miss since snapshot LED colors was a new feature. I think the test plan should've included testing global setting options. Quote Link to comment Share on other sites More sharing options...
markus506 Posted November 24, 2016 Author Share Posted November 24, 2016 Thanks for confirming, guys. I'll point support in my ticket to this thread. Quote Link to comment Share on other sites More sharing options...
hefonthefjords Posted November 24, 2016 Share Posted November 24, 2016 There are a few faults regarding this.The above LED Dim/Off bug.Also, if you swap snapshot button positions the assigned LED colour gets left behind and you have to manually change it. Quote Link to comment Share on other sites More sharing options...
patrick_g_nelson Posted November 28, 2016 Share Posted November 28, 2016 Thanks for confirming, guys. I'll point support in my ticket to this thread. Did you ever hear back again after pointing them to this thread? This definitely reproduces so hopefully they look into it more. Quote Link to comment Share on other sites More sharing options...
markus506 Posted November 28, 2016 Author Share Posted November 28, 2016 Did you ever hear back again after pointing them to this thread? This definitely reproduces so hopefully they look into it more. No, I haven't heard anything yet. I am hoping that support will view this thread, and be able to reproduce, because it's a pretty obvious issue. Quote Link to comment Share on other sites More sharing options...
kjonsson Posted November 29, 2016 Share Posted November 29, 2016 ***** Also, if you swap snapshot button positions the assigned LED colour gets left behind and you have to manually change it. Ouch, thanks for the heads up on that one! Hope it'll get fixed soon..! Quote Link to comment Share on other sites More sharing options...
