LeanderLeitner Posted November 26, 2016 Share Posted November 26, 2016 Hi!I connect my PODXT with my computer via USB....Windows -> sound -> PODXT as playback and recording device. I am able to record my guitar signal (the dry signal I want) in my recording software. However, the signal is too loud and sometimes clips. Changing the output knob of my POD or the chan volume OR Line 6 device volume only lowers the volume what I hear (PODXT sound, drum track etc....)...but no matter what I change, the guitar signal is always too loud and I don't know how to lower its volume. Help please! Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted November 28, 2016 Share Posted November 28, 2016 Does your guitar have active pickups (battery on board) by chance? I have heard of this problem happening with active pickups, the solution is to use a buffering stompbox pedal between guitar and Pod. Quote Link to comment Share on other sites More sharing options...
LeanderLeitner Posted November 28, 2016 Author Share Posted November 28, 2016 Thanks for your reply!No, I don't have active pickups. I have an Ibanez RG 350EX (standard INF pickups). Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 28, 2016 Share Posted November 28, 2016 You need to use the DAWs input control to lower the signal coming in (there should also be a windows input mixer control in the Control Panel -> old version of Windows btw). That is where I would look. Quote Link to comment Share on other sites More sharing options...
LeanderLeitner Posted November 28, 2016 Author Share Posted November 28, 2016 Thanks but there is none. My soundcard is a Delta 1010LT. When connecting the POD to my normal soundcard (output -> card input WITHOUT USB) I can adjust the volume in my soundcard's mixer.However, when using USB recording the POD becomes the soundcard! Neither the knobs nor the Windows mixer sliders change anything. The guitar signal always stays the same. I can even set the playback device volume of the POD in the Windows sound settings to 0 AND the recording volume of the POD in the Windows settings to 0 and still recording the signal results in a too loud file. I have Cakewalk Sonar. I arm an audio track for recording by clicking the R icon...then select "POD XT In" as input signal....and this signal is always too loud, no matter what settings I change. :( Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 29, 2016 Share Posted November 29, 2016 In the Control Panel have you adjusted the signal in "Audio-Midi" devices (I think that's the name). There is control for signal strength going "into" the DAW - I don't have Sonar so I am SOL on that. Quote Link to comment Share on other sites More sharing options...
LeanderLeitner Posted November 29, 2016 Author Share Posted November 29, 2016 I know but it does not work! It only changes what I hear but not what is recorded. I tried everything. Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 29, 2016 Share Posted November 29, 2016 There should be a Volume "Trim" somewhere in the DAW to control the levels being recorded. Hopefully someone who knows Sonar will pop up. Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 29, 2016 Share Posted November 29, 2016 Make sure your are selecting Line6 ASIO as your device in your DAW. Quote Link to comment Share on other sites More sharing options...
LeanderLeitner Posted November 29, 2016 Author Share Posted November 29, 2016 Thanks. Windows: everything set to POD. DAW: everything set to POD. Changing the input slider of the recording device ("Aufnahme") does not affect the volume. Yes, it is set to 100 but changing it to 0 does not do anything. Changing the output slider of the playback device ("Wiedergabe") only affects what I hear...what is the second tab (green) for? I can select some standard device...what does it do?Btw, you cannot control the input volume in Sonar. You have to adjust the volume BEFORE recording files in Sonar.http://forum.cakewalk.com/Input-volume-not-working-Sonar-8-m1605306.aspx Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 29, 2016 Share Posted November 29, 2016 There are no no software controls that will alter the unprocessed guitar signal sent from the PODxt via USB. You likely already have, but can you confirm in the Line6 Audio-MIDI control panel that you are sending the unprocessed signal and not reamping? Can you post a snapshot of your device selection in your DAW? Quote Link to comment Share on other sites More sharing options...
LeanderLeitner Posted November 29, 2016 Author Share Posted November 29, 2016 What should I select in Sonar (track input? Mono POD L, Mono POD R or Stereo POD L+R? Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 29, 2016 Share Posted November 29, 2016 That really depends on your workflow. All the settings look good. Is it possible the clipping is occurring somewhere in the monitoring? Can you post a snapshot of the waveforms that are too loud/clipping? Quote Link to comment Share on other sites More sharing options...
LeanderLeitner Posted November 29, 2016 Author Share Posted November 29, 2016 It doesn't clip while playing power chords or single notes. I get the clipping when strumming all six strings (percussion style) hard....mostly...sometimes also during normal play but seldomly. Can't post a screenshot at the moment as I do not want to change my guitar's volume setting. I have an Ibanez RG 350 EX with standard INF pickups. I use the bridge pickup.I will test it with my Fender Stratocaster to see if there is a difference. Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 30, 2016 Share Posted November 30, 2016 Does changing the "gain" setting to -18db (AISO page) help? Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 30, 2016 Share Posted November 30, 2016 Does changing the "gain" setting to -18db (AISO page) help? I think that setting dims non solo tracks. Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 30, 2016 Share Posted November 30, 2016 Just grasping my man! On a Pro its easy but I cannot recall a method other than the Channel Vol which the OP sez didn't work. Dropping the signal via the EQ could work but is not really the solution. Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 30, 2016 Share Posted November 30, 2016 Just grasping my man! On a Pro its easy but I cannot recall a method other than the Channel Vol which the OP sez didn't work. Dropping the signal via the EQ could work but is not really the solution. I know, So am I !! :) The only way I know of is to dim the signal before it goes into the POD, like roll off the guitar volume, adjust pick-up height, something between guitar and POD....but then you're altering your tone. Yeah, the channel volume will only affect the processed signal. I guess another work around would be to create a transparent as possible patch and send the processed signal and use the channel volume. Quote Link to comment Share on other sites More sharing options...
LeanderLeitner Posted November 30, 2016 Author Share Posted November 30, 2016 Ok, did some testing.Ibanez RG 350 EX, INF pickups (default ones), humbuckers, bridge pickup: seldom clipping!Fender Stratocaster MN, default pickups, single coils, bridge pickup: no clipping!Both guitars don't have new strings...the Ibanez is louder.I have two pedals, a Digitech Whammy and a Dunlop Wah. The Wah does not change the volume but the Whammy decreases the volume...I have to set the guitar knob to 100% and I don't get any clipping.The volume knob of the Fender gradually increases volume...making volume swells easy. The Ibanez goes from silent to loud in only 20% of the knob range..and gets even louder at full volume.I don't have a problem setting the volume to a medium setting as the tone is not worse (compared to 100% volume)....however, my question is if getting a new guitar port (Line 6 port or Pod HD) will fix my problem or if my clipping will remain. Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 30, 2016 Share Posted November 30, 2016 Did you try lowering the EQ level? that should lower the output vol and might help your clipping cease. I like the HD myself (but still use XTs/X3s) the HD lets you pad the input but still you "can" make it clip. :) Or you can pop a buffer pedal in the XT's chain. Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 30, 2016 Share Posted November 30, 2016 As BillBee mentions, the POD HD (500 and Pro) can pad the input, (the desktop bean cannot). The UX2 also has a guitar pad input that you can use if you are clipping the regular guitar input (GX and UX1 does not). If you are just wanting to get an unprocessed guitar signal into your DAW, the POD HD would be overkill. Quote Link to comment Share on other sites More sharing options...
LeanderLeitner Posted November 30, 2016 Author Share Posted November 30, 2016 Thanks! The EQ level of...the guitar? What do you mean? Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 1, 2016 Share Posted December 1, 2016 The EQ in the XT. Lower the level on everything uniformly that way it is one way to lower the overall volume. Instead of boosting frequencies you are reducing them. Might work. Quote Link to comment Share on other sites More sharing options...
LeanderLeitner Posted December 1, 2016 Author Share Posted December 1, 2016 But when recording via USB the POD and all its settings is bypassed....only the pure guitar signal is recorded. Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 1, 2016 Share Posted December 1, 2016 Take this with a grain of salt as it has been a year since I recorded with the XT. :) But when I record with the XT/Gearbox (yep the old faithful GB) the patches on the unit are what is being recorded by the DAW. So when I change a patch on the XT the tone changes to what is being recorded. I am not taking in a dry signal though that could be done. I might be able to dig the XT out and fire up it up in the next day or so but it depends on what the band has up for some make up days. Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 1, 2016 Share Posted December 1, 2016 But when recording via USB the POD and all its settings is bypassed....only the pure guitar signal is recorded. Except of course for the pedals you have going in front of the xt. Many pedals that has their own power source may act as a preamp. Quote Link to comment Share on other sites More sharing options...
