pod hd500x volume problems
laggyluk
1. if you can't strum the "same strength" every time, then you shouldn't be recording anything.
2. your recording engineer/producer should be twisting the knobs to balance everything. not you.
But, I guess that isn't fixing the problem of "different volumes every time you power up".
So, tell us more about this problem. Be specific with what you are doing.
I don't adjust anything, not touching any knobs. Just power the thing, record some licks through analog out, call it quits. Next day same setup but in DAW I get random drop in volume, significant enough to hear and see the difference.
