laggyluk Posted December 8, 2016 Share Posted December 8, 2016 Each time I power it on I get different volume level which is super annoying in recording sessions Any way to fix it? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted December 8, 2016 Share Posted December 8, 2016 You think it is super annoying. But I think you are acting super amateurish by not checking recording levels for each take. Quote Link to comment Share on other sites More sharing options...
laggyluk Posted December 8, 2016 Author Share Posted December 8, 2016 And I'm supposed to build a robotic arm that will strum with same strength every time to setup them? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted December 8, 2016 Share Posted December 8, 2016 1. if you can't strum the "same strength" every time, then you shouldn't be recording anything. 2. your recording engineer/producer should be twisting the knobs to balance everything. not you. But, I guess that isn't fixing the problem of "different volumes every time you power up". So, tell us more about this problem. Be specific with what you are doing. Quote Link to comment Share on other sites More sharing options...
laggyluk Posted December 8, 2016 Author Share Posted December 8, 2016 I don't adjust anything, not touching any knobs. Just power the thing, record some licks through analog out, call it quits. Next day same setup but in DAW I get random drop in volume, significant enough to hear and see the difference. Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted December 8, 2016 Share Posted December 8, 2016 Turn all knobs to zero, except the master-volume, which indicates your monitoring-level. Do not save the patch with those so reduced knobs! Recall the patch. This protects knobs from being tickled somehow by minimal vibrations or things like that. Quote Link to comment Share on other sites More sharing options...
line-6-user Posted December 9, 2016 Share Posted December 9, 2016 You say that the recording is done through the analogue outputs... Check that the pots on the analogue input/s are not dirty, making a bad contact. This ca affect volume changes. Quote Link to comment Share on other sites More sharing options...
