r_hayward01 Posted December 27, 2016 Share Posted December 27, 2016 Hi, I am hoping someone can help me. I was bought a UX2 for Chrismas which I am now using as my interface when recording in to the DAW (I use reaper). Pod Farm 2 works fine as a stand alone program as in I can hear it and modify tones etc... I have managed to record the wet and dry tones into reaper but when I come to add Pod Farm as a plug in effect to the dry track I encounter problems. I can select Pod Farm 2 as the plugin and it opens the User Interface but there is no input signal showing in Pod Farm. I can hear the dry guitar signal playing back but there is no input showing on the meter in the plugin and no matter what presets I select no effect is added. Ideally I want to record dry tracks and add/tweak effects later so am eager to work out how to add these effects to a dry guitar track. What am I doing wrong? Is something routed incorrectly in either PodFarm or Reaper? Can someone help? Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 29, 2016 Share Posted December 29, 2016 Did you run the license manager? Quote Link to comment Share on other sites More sharing options...
mrkhmusic Posted January 1, 2017 Share Posted January 1, 2017 I'm having a similar problem. I'm trying to apply pod farm to dry tracks. I recently bought a kb37 used, and that's how I acquired pod farm. When I insert pod farm as the plugin, I get this message: "No authorized device An required device is either not authorized or not connected. Pod Farm's GUI will operate during this session, but the plug-in will not process audio. Please connect your iLok or Line 6 hardware and restart the application. Click anywhere to dismiss this message." I have the kb37 plugged into the computer. What is the license manager you mentioned? Thanks much in advance! Quote Link to comment Share on other sites More sharing options...
mrkhmusic Posted January 1, 2017 Share Posted January 1, 2017 Well! Never mind! I found it! I found the license manager and ran it, and all is well! Thanks! Quote Link to comment Share on other sites More sharing options...
