pevjan Posted February 6, 2017 Share Posted February 6, 2017 Hi, In between 2 rehearsals, where my Pod X3 Live was just sitting alone in the dark cursing my name, something changed. I noticed that the sounds were slightly off. Then I noticed the following: I have two presets next to each other. Preset A has delay turned off on Tone 2. Preset B has delayed turned on on Tone 2. They are based on each other, i.e. I created Preset B by saving Preset A to it. This has worked fine for months. But now they both either have delay turned on or off, I can't have Preset A have it off and Preset B on. If I turn off delay on Preset A it changes Preset B to be turned off when I save A. If I switch to tone 2 on Preset A and then go to the next song and switch to Preset B, both Tone 1 and Tone 2 are active. That didn't use to be the case. If I save Preset B so that only Tone 1 is active and then switch back and forth again both tones are active. I'm running the most recent Flash Memory version (2.01). I've tried downgrading a couple of versions (2.00, 1.21) but it still behaves the same. I've deleted all the resets as well and it still does the same thing. My theory is it's a bug, because the behaviour changed between two rehearsals when it wasn't used. Just rebooted. But I could also have made a config change somehow that made it behave like this and then forget what I did. It's very possible, but I don't know what. Ideas? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 6, 2017 Share Posted February 6, 2017 Sounds like you have activated the Lock Tone 2 feature. Turn it off. Quote Link to comment Share on other sites More sharing options...
pevjan Posted February 6, 2017 Author Share Posted February 6, 2017 So simple, so right! Didn't know about that feature! Thanks! Quote Link to comment Share on other sites More sharing options...
