jedishane7
Spider V 240 Pitch Bending/ Whammy effect?
I'm having trouble figuring out how to assign the pitch bending effect to the volume pedal on the FBV 3 Shortboard. I see where you select the heel/toe percentages. But, nothing for the pedal.
Any help with this would greatly appreciated.
In the Spider Remote app, you just hold down on the "Position" parameter for a few seconds, and a dialog box pops up asking you if you want to assign that parameter to the expression pedal. I'm not sure about how to do it on the amp itself... I would need to dig into the manual for that.
That's actually not the way it works. Double tap on the blank area( outside of the slider) of the parameter you want to control with the Exp. pedal and a dialog box will pop up. BTW, is there a manual or guide on the Spider Remote App? I've had to discover things by experimenting- not the best way to learn it.
Just tried it, and it seems both ways work, at least on the iPhone. Double-tapping is faster, though. And, actually it seems double-tapping anywhere along the parameter bar itself works.
I tried holding the position parameter, nothing happened on my Ipad mini...
Yeah, double-tapping is probably the prescribed method. Funny, though, on my iPhone if I hold for three seconds that same window pops up. Perhaps it's related to the 3D Touch/Long Press features that came out with the iPhone 6s.
Is there a way to do this without having a physical petal?  I'd like to have the eqivalent of a pitch bent pedal that's been bent down one semitone.  (The equivalet of drop tuning).  I don't have an iOS or Android device, so I need to do this from the amp itself.  When I edit a patch (press the Edit button) I can scroll down to a WAH section, and I see a number of options for the WAH, but none of them seem to be pitch bend.  Any help would be appreciated.
Mike
Mike
Check your other post regarding pitch bend
Same ans though:
Select the Pitch modulation Type
Select Pitch Bend for the effect  press OK
Set Position at 50%
Set Heel to -1  (drop down 1 semitone; -2 for whole step drop etc)
Set Toe to 0
Set mix to 100%
At a good volume level you won't hear much of the strings tuning bleed of your guitar itself, at low volumes it can be distracting
Thanks again GuitarDad!   (To be clear for anyone who didn't see my other post.  The Pitch Bend is in the SYN section, not MOD or WAH.)
