Gepcat Posted March 29, 2017 Share Posted March 29, 2017 Have an Analogman fuzz going into the loop... Works fine on its own but thru the loop I'm getting a high pitch squeal. Is there something I need to change... I have an old Rat pedal in the other loop and it's fine.... Quote Link to comment Share on other sites More sharing options...
Inerzia Posted March 29, 2017 Share Posted March 29, 2017 Maybe it's one of those pedals that don't tolerate buffered signals in front of them.Three out of four of my fuzzes are that way, and as I understand, that's a very common trait. Quote Link to comment Share on other sites More sharing options...
Gepcat Posted March 29, 2017 Author Share Posted March 29, 2017 If that's the case, is there anything that can be done to remedy this... It's one of my favorite pedals.... Quote Link to comment Share on other sites More sharing options...
FlyingsCool Posted March 29, 2017 Share Posted March 29, 2017 Put it in front of the Helix? Quote Link to comment Share on other sites More sharing options...
Gepcat Posted March 29, 2017 Author Share Posted March 29, 2017 That's possible.... Please keep the ideas coming... Would prefer to keep it in the loop because all the great possibilities that can be done with it.... Quote Link to comment Share on other sites More sharing options...
EdwinV Posted March 29, 2017 Share Posted March 29, 2017 That's possible.... Please keep the ideas coming... Would prefer to keep it in the loop because all the great possibilities that can be done with it.... You haven't mentioned which AnalogMan Fuzz you have. If it's a Sunface, the only way is to put it in front of the Helix. In the conventional setup you would also put this first in the signal chain after your guitar. It does work with few 'true bypass' effects in front of it, but will act strangely when confronted with a buffered input signal. The AnalogMan Astrotone Fuzz is supposed to be less sensitive to a buffered input signal and may work better in the loop. Haven't tested this myself though. If I have some spare time I may try this. I have several Sun Faces, Sun Lions, Astrotones and a Sunbender lying around. Really love those fuzz boxes, but the Helix is so incredibly convenient and sounds great too Quote Link to comment Share on other sites More sharing options...
Gepcat Posted March 29, 2017 Author Share Posted March 29, 2017 Yes, it is the sunface and the sun lion (I use either or). Is there any way to put something additionally into the loop that would help correct the buffer? I have an American Looper that they worked fine with... Quote Link to comment Share on other sites More sharing options...
Inerzia Posted March 29, 2017 Share Posted March 29, 2017 I asked a similar thing a while ago, and somebody recommended a Radial Dragster, but I didn't try it.It's 50$ for a pot in a box so... I figured it would be more convenient to just use the models inside the Helix, which are pretty decent.My favorite fuzz is the FZ-2 (which works just fine wherever you put it) and now that's in the Helix too, as the Wrangler, so I dropped it. Quote Link to comment Share on other sites More sharing options...
Gepcat Posted March 29, 2017 Author Share Posted March 29, 2017 How would I use that? Put it in the loop along with the fuzz? Quote Link to comment Share on other sites More sharing options...
Inerzia Posted March 29, 2017 Share Posted March 29, 2017 yes, before the fuzz, it's supposed to "debuffer" your signal. Notice the quotation marks... that's not tech talk at all :D Quote Link to comment Share on other sites More sharing options...
salty09 Posted March 29, 2017 Share Posted March 29, 2017 Not sure if it will help with that or not, but have you tried putting that loop first in the chain and setting the input impedance to like 10K? I notice that can make a big difference with my Red Witch Fuzz God 2. Quote Link to comment Share on other sites More sharing options...
Gepcat Posted March 29, 2017 Author Share Posted March 29, 2017 Do you mean placing it in loop #1 ? Where do you find the imprudence selector? I will read up on it....I have not seen anything On being able to select the impedance Quote Link to comment Share on other sites More sharing options...
salty09 Posted March 29, 2017 Share Posted March 29, 2017 Do you mean placing it in loop #1 ? Where do you find the imprudence selector? I will read up on it....I have not seen anything On being able to select the impedance Which loop is probably not as important as making sure that loop is placed first in the chain of the patch and then go into the input block on the patch and change the impedance there. It is located on the input block and probably is set to auto by default. You can adjust the value. I found 10K works for my fuzz god 2, which is a fuzz face type circuit. Not sure if it will help or not, but worth a try. Also, I had one pedal that seemed to be noisy in the loop and I put a noise gate right after it and it resolved the problem. Because the noise was faint, it was easy to kill it without really changing the signal at all the rest of the time. Quote Link to comment Share on other sites More sharing options...
