beauviarts Posted April 17, 2017 Share Posted April 17, 2017 Hello, So I acquired an HD500 through a trade. It has been a little work as I discovered I was given the wrong power supply for the unit and it would overheat and restart mid-gig. I purchased the correct one and everything has been great. Every once in a while my FS3 freezes up but seems to work after a few minutes. Sometimes it works immediately. I took the pedal apart and blew some dust out and it hasn't really given me any issues. All has been well EXCEPT today=( I booted up my HD500 and the entire bottom row of footswitches were not working at all. I immediately thought that it sounded like a software issue or the ribbon connecting the bottom portion was disconnected or something. So, I took it apart again and everything seemed fine. The strange thing? I reassembled the board and googled for about 10 additional minutes. I plugged it back in and the switches work perfectly. The firmware is up to date and I just want to know: Has anyone else experienced this? If so, what the hell is happening? How can I rectify this and avoid this issue in the future? I appreciate any comments ahead of time. Thanks guys, Beau Quote Link to comment Share on other sites More sharing options...
Brazzy Posted April 18, 2017 Share Posted April 18, 2017 All I can attest to is that some strange glitches, bugs and hardware issues can happen with it. Anything from sudden volume issues to footswitches not responding properly and other things but overall my HD500 still seems to work for the most part and I still have the original power supply. On the other hand I don't gig with it so it doesn't get roughed up, subject to other power sources or exposed to the weather. It does however have many hours on it and has never been taken apart. I can say the same thing about my X3 Pro. 1 Quote Link to comment Share on other sites More sharing options...
beauviarts Posted April 18, 2017 Author Share Posted April 18, 2017 I think you guys are hitting the nail on the head! Maybe that's why they released 500x shortly(ish) after. In any regards, thank you both! Quote Link to comment Share on other sites More sharing options...
BillBee Posted April 18, 2017 Share Posted April 18, 2017 I wouldn't poo poo the switch assemblies too badly based on a used unit you picked up in a trade. The tactile switches that are used are in many things and are fairly reliable (same ones are used in the old GNX series IIRC). Anywho replacement upper and lower switch assemblies are pretty cheap if that is the problem (and you don't want to solder) and DeOxit can breath some life into them assuming its an actual switch issue. Sometimes it is the ribbon cable itself that goes bad, oxidized connector pins or there may be a cold solder joint. The 500x (IIRC) was released due to parts availability for the 500 getting slim. 1 Quote Link to comment Share on other sites More sharing options...
bjnette Posted April 19, 2017 Share Posted April 19, 2017 I agree with BillBee. Buying a computer used is always a risk. Who knows how much rough treatment it got. Hopefully something can be done about it. Always first is the power supply itself. Strange errors mostly on booting up has come up too many times. But you have handled that. If the old PSU was over spec'd that could be the issue if under spec'd less likely. Ribbon cables are glued at the clipped join. Unlikely but who knows what sort of environment it has been in. If you or someone else has opened it up before remember that most problems are caused by the user when they first get a unit. What changed? Buy a can of compressed air and get under those switches with it and or deoxit. Next would be to go to the most suspect switch and replace it. 1 Quote Link to comment Share on other sites More sharing options...
bjnette Posted April 19, 2017 Share Posted April 19, 2017 Got site access probs as I tried to edit previous post. It looks like you might of solved it and will never get a prob again! 1 Quote Link to comment Share on other sites More sharing options...
bjnette Posted April 19, 2017 Share Posted April 19, 2017 After re reading your post! Quote Link to comment Share on other sites More sharing options...
