Alsklaftsk123 Posted September 16, 2013 Share Posted September 16, 2013 Hi, if i have a dual amp patch and want to only use 1 amp, how do i do it? It always is a "hole" where the other used to be. Also where do i controll how dual amps are panned, what is stereo fx etc? I want ALL of my patches in mono, so i can use a single xlr. Quote Link to comment Share on other sites More sharing options...
StephenSLR Posted September 17, 2013 Share Posted September 17, 2013 pan path A hard Left and you'll get a perfect summed to mono signal Oh wow, I'd mute Amp B and pan Amp A to centre but I only use the left 1/4 output to my live amp. Will panning it 100% left make it sound fuller? s Quote Link to comment Share on other sites More sharing options...
Alsklaftsk123 Posted September 17, 2013 Author Share Posted September 17, 2013 If i mute path b, will then the block it used to be in disappear? Quote Link to comment Share on other sites More sharing options...
Alsklaftsk123 Posted September 17, 2013 Author Share Posted September 17, 2013 Yeah, but how can i make it look like a normal single amp patch? Quote Link to comment Share on other sites More sharing options...
Alsklaftsk123 Posted September 17, 2013 Author Share Posted September 17, 2013 So there basiclly is no way to make the amp b block go away? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 17, 2013 Share Posted September 17, 2013 i believe its as simple as selecting one of the amps and using the direction key on the unit.. maybe enable it to move? i don't know if that makes any sense... but i've done it before and it was dirt simple... just don't bother with the dual tones much. Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 17, 2013 Share Posted September 17, 2013 To remove the double amp block, first place all FX outside the dual-amp rectangle on the display, either pre or post. Your signal path should now look like a single straight line except for the dual-amp rectangle. Now select the top amp and use the Move function (or drag/drop in HD Edit) to move it left, outside of the rectangle. As this happens the rectangle should disappear leaving you with the single amp path display. 1 Quote Link to comment Share on other sites More sharing options...
Alsklaftsk123 Posted September 17, 2013 Author Share Posted September 17, 2013 Ok thank you!! Is there a way to organize and move patches around without using the pod hd edit? Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 17, 2013 Share Posted September 17, 2013 Yes, but it's much more difficult without using the editor. The manual will describe it - using the SAVE button on the device. You may need to set aside one preset slot as a temporary buffer to hold a preset that you don't want to overwrite with the SAVE feature. It's a bit of a juggling act, and not nearly as visual as with the editor. Quote Link to comment Share on other sites More sharing options...
StephenSLR Posted September 18, 2013 Share Posted September 18, 2013 the 1/4 Out only when used mono should not change because from there you get always L+R I use the 1/4 out mono left to my amp on stage, so is it best to pan 100% to path A? I don't use two amps on stage so have no need for a stereo signal. s Quote Link to comment Share on other sites More sharing options...
