Hi I have a certain problem with the noise gate on my M5, I found the separate setup under dist group, but each preset has its own noise gate on additional setup (page 2). Now the manual says that I can access the page 2 setup by pushing the model select knob once on the preset. I did exactly that and it just switches thru effect groups.
Can anyone advice?
I believe that all the Setup parameters are global.  To access Page 2 you need to press and hold the TAP footswitch, then press the Model Select knob to enter Setup.  Press it again to enter Page 2 of Setup.  Make your global Gate adjustments there.  They are not separate for each effect.
