ginster Posted May 2, 2017 Share Posted May 2, 2017 I had a Zoom G1Xon connected to the Trio+ with no problems. Since I received a pod hd400 yesterday I tried to connect it the same way.I noticed some sort of distortions or overdriving effects.I cabled as follows: Guitar>Trio guitarinput. Trio FXsend >Input guitar pod Trio FXreturn>output pod Trio Mixer out>Mixer>PowerAmpThanks for help. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted May 2, 2017 Share Posted May 2, 2017 you might need to set the output level on your trio FX send to instrument level...Also, make sure the POD output level is set accordingly,,,If it needs to be instrument, set the level to AMP....otherwise use LINE if you need line level. Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted May 2, 2017 Share Posted May 2, 2017 .. and put input 1 to Guitar and input 2 to an unused device on the POD (like Variax or Aux in each patch (or global)). Quote Link to comment Share on other sites More sharing options...
ginster Posted May 2, 2017 Author Share Posted May 2, 2017 .. and put input 1 to Guitar and input 2 to an unused device on the POD (like Variax or Aux in each patch (or global)). I'm afraid but the HD400 only has 1 input. Quote Link to comment Share on other sites More sharing options...
bjnette Posted May 2, 2017 Share Posted May 2, 2017 Actually the Trio is devil's evil. Not okay to be replacing the bass n drums. You will soon tire of it! LOL Seriously destroy them all! For routing the Trio would be best inserted into the FX return and back in via the normal HD output! Quote Link to comment Share on other sites More sharing options...
ginster Posted May 3, 2017 Author Share Posted May 3, 2017 Thanks for all your replies. Will try out. Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 3, 2017 Share Posted May 3, 2017 I just have the regular Trio but I use an A/B switch prior to so I can route the signal direct to the HD after getting the Trio going. For monitoring the HD goes to an amp and the Trio to either a separate amp or PA. Sometimes I will route both to a mixer then to the PA. Quote Link to comment Share on other sites More sharing options...
ginster Posted May 3, 2017 Author Share Posted May 3, 2017 Actually the Trio is devil's evil. Not okay to be replacing the bass n drums. You will soon tire of it! LOL Seriously destroy them all! For routing the Trio would be best inserted into the FX return and back in via the normal HD output! I'm a lonely child. There is nobody to play with. It's a drag. So Trio+ is my mate! Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 3, 2017 Share Posted May 3, 2017 I'm a lonely child. There is nobody to play with. It's a drag. So Trio+ is my mate! The TP+ is pretty cool with the "tamed" bass player. Prior to the firmware update, the Regular Trio was a free formed jazz oddessy. Quote Link to comment Share on other sites More sharing options...
bjnette Posted May 3, 2017 Share Posted May 3, 2017 It is an amazing bit of kit. Reminds me of the auto accompaniment on a keyboard. You do get sick of it eventually, but I got to say the simple bass makes it much more guitarist centric! Be interesting to see where they take it from here. Quote Link to comment Share on other sites More sharing options...
