psycho4577 Posted July 5, 2017 Share Posted July 5, 2017 Hello, I'm about to buy a Helix LT, and I would lie to know how could I plug it. Is it possible to plug the guitar in guitar in--->1/4"-->Amplifier AND in the same time using the send/return plugs in the FX loop of the amplifier? In order to use modulations like chorus/delay/reverb in the FX loop and the other effects like distorsion, compression, eq in front of the amplifier. Thanks, Ludo Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted July 5, 2017 Share Posted July 5, 2017 Yes Sir, it is very possible. There are plenty of resources on this forum, or the internet in general, on how to set up what is called four-cable-method. In Helix there are also factory presets to help you get started. The presets you want are in setlist 8 (labeled "Templates"), and have all of the necessary routing built-in. Quote Link to comment Share on other sites More sharing options...
SymphonicDischord Posted July 5, 2017 Share Posted July 5, 2017 Yep, 4CM is easy peasy with Helix. Quote Link to comment Share on other sites More sharing options...
psycho4577 Posted July 5, 2017 Author Share Posted July 5, 2017 It's really cool ! Thanks guys :p I think of buying one quickly :p Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted July 5, 2017 Share Posted July 5, 2017 And after you are connected to your favorite amp with the 4 cable method, you can connect to two powered FRFR PA speakers via XLRs, so you can have Wet in stereo, giving you a full wet/dry/wet system. Quote Link to comment Share on other sites More sharing options...
psycho4577 Posted July 7, 2017 Author Share Posted July 7, 2017 I see! Oh I've Another question. I have a Yamaha THR100 HDual amplifier, it can create really cool tones too, I can plug it in Stéréo and use its speaker simulator on each channel (I can use both the first and the second at the dame time). My question is, should I use this amplifier or should I but another one because of the hélix lt? Maybe a single clean channel would be better with the Helix lt no? Like a fender twin reverb or a peavey classic 30? What is your own config? Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted July 7, 2017 Share Posted July 7, 2017 The THR100 Dual Channel Amp should work great with Helix. Especially, as the Yamaha offers the fleibility to select the power tubes in each Amp section. This should give you plenty of additional versatility with the Helix! Quote Link to comment Share on other sites More sharing options...
psycho4577 Posted July 7, 2017 Author Share Posted July 7, 2017 I think it might be a good combination ^^. I will test it anyway ahah I just wonder what kind of saturation I should use. The one on the amplifier or the one on the hélix. Choosing the amplifier's may be annoying (the way to activate, kicking two switchs at the dame time) Quote Link to comment Share on other sites More sharing options...
