slontje Posted July 10, 2017 Share Posted July 10, 2017 Greetings, Line6 monkey sees the variax, yet the workbench software wont see the guitar anymore. used to work, dont know what changed other than POD HD500x flash update. Anyone else having this issue? running windows 10, tried all compatibility modes. phone support says it should work, but it doesn't. again, it used to work perfectly fine until today. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted July 10, 2017 Share Posted July 10, 2017 The older Variax's like the Variax 700 works with Workbench, but not Workbench-HD. Older Variax patches are not able to port over to the Workbench-HD format. Have to use the earlier Workbench with a 700. Quote Link to comment Share on other sites More sharing options...
slontje Posted July 10, 2017 Author Share Posted July 10, 2017 sorry, i should have mentioned i'm using the normal workbench software. not the HD :) and updated the hd500x flash today. have been without internet for a couple of weeks. Quote Link to comment Share on other sites More sharing options...
eenymason Posted July 12, 2017 Share Posted July 12, 2017 The older Variax's like the Variax 700 works with Workbench, but not Workbench-HD. Older Variax patches are not able to port over to the Workbench-HD format. Have to use the earlier Workbench with a 700. Correct me if I'm wrong, but I was under the impression that the 500X only acts as a go-between with JTV/Standard, and Workbench HD, NOT Legacy model variax, and Workbench. I believe you need an HD500 for this task, not HD500X. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted July 12, 2017 Share Posted July 12, 2017 The VDI interface device is used to connect the guitar to Workbench or Workbench HD. The 500X had the "go-between" Flash update capabilities. Not certain about Workbench or Workbench HD connectivity. Early on the 500 didn't have that, the "go-between" connecting, if I recall was a later update to the 500 firmware to allow Flash update of guitars. Don't know about connecting to Workbench or Workbench HD thru a 500. Also, firmware up to and including Flash v1.90 on the JTV, and v3.25 for Variax Acoustic will run on Workbench. Variax Acoustic won't run on Workbench HD, that is for Firmware v2.00 or higher, and for JTV, Standard and Shuriken. Quote Link to comment Share on other sites More sharing options...
