jamieabraham Posted September 28, 2013 Share Posted September 28, 2013 Hi I wanted to ask if anyone else has experienced this problem with the DT25. I was getting a slight shock whilst holding my guitar and touching anything earthed. So I took my amp in to the local repair guy and sure enough it wasn't earthed properly. However, according to him the fault is in the amps design and so presumably they will all behave this way! I'm no electrician so below is exactly what he said: "The front end design of this is odd - both electrically and mechanically. It has a sub PCB connected directly to the (stereo type) i/p socket, which is then connected back to the main board by an unscreened lead. Although the sleeve contact reads to earth, the actual socket nut is floating. Also the back pad is only power grounded by way of its securing screws. I have now added a wire straight from the power i/p socket earth pin to the back panel and then carried it on to the shield at the i/p socket, so at least now it's guaranteed safe." This mod cost me £30 but I really want to know if any other DT25 owners have had this issue. thanks Quote Link to comment Share on other sites More sharing options...
stumblinman Posted October 3, 2013 Share Posted October 3, 2013 I haven't. Gigged my DT25 numerous times and have not experienced that. I hope there are no lingering effects for you, unless it made you play better. If so, do it again! \m/ Quote Link to comment Share on other sites More sharing options...
jamieabraham Posted October 4, 2013 Author Share Posted October 4, 2013 No and ...no! It was a tiny amount of voltage like a static shock and only when I touched something metalic that was earthed - in this case my laptop. Quote Link to comment Share on other sites More sharing options...
stumblinman Posted October 4, 2013 Share Posted October 4, 2013 Was it a continuous tingle of current, or just a quick zap? Quote Link to comment Share on other sites More sharing options...
spaceatl Posted October 4, 2013 Share Posted October 4, 2013 I have not had this problem because I use an AVR on my input power for my gear. transformers isolate that garbage voltage....Even when I was playing on Mars last week, I did not have a "Marsing" problem... :D Quote Link to comment Share on other sites More sharing options...
jamieabraham Posted October 21, 2013 Author Share Posted October 21, 2013 Was it a continuous tingle of current, or just a quick zap? It was a continuous tingle. Quote Link to comment Share on other sites More sharing options...
jamieabraham Posted October 21, 2013 Author Share Posted October 21, 2013 I have not had this problem because I use an AVR on my input power for my gear. transformers isolate that garbage voltage....Even when I was playing on Mars last week, I did not have a "Marsing" problem... :D Forgive my ignorance spaceati - what's an AVR? Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted October 21, 2013 Share Posted October 21, 2013 automatic voltage regulator Quote Link to comment Share on other sites More sharing options...
stumblinman Posted October 21, 2013 Share Posted October 21, 2013 It's funny, well not really funny, but an interesting coincidence: When I was changing my tubes the other day after the fuse blowout ordeal, I tested the amp before putting it back together. Head was lying on the floor next to the cab it's housed in, and while I was holding my guitar while I bent over to flip standby off, I was getting a minor tingle of electricity present while my fingers were on the standby switch. Not strong by any means, but definitely present and noticeable. Odd thing was, when I reassembled the amp, the sensation went away. Maybe next time I crack it open I will do this grounding mod you posted. Edit! I now realize I was plugged in direct when testing it, and after reassembling it I was using L6 Link. That must separate you from the power inherent in the amp circuit. Perhaps I will test and see if I get zapped with amp reassembled and plugging straight in. Quote Link to comment Share on other sites More sharing options...
