chief_wigam Posted October 16, 2017 Share Posted October 16, 2017 I tried my headphones into my firehawk for the first time today. I used 2 different headphones and neither worked. I have used the firehawk in a PA and it worked fine. But with the headphones, I used a 3.5mm connection into a 1/4" adaptor, plugged in the guitar Into the firehawk but no sound. Anyone experienced this? Quote Link to comment Share on other sites More sharing options...
JamieCrain Posted November 2, 2017 Share Posted November 2, 2017 No, have you tested the headphones and adapter in a different device? Need to rule out a faulty adapter. Quote Link to comment Share on other sites More sharing options...
sainthooligan Posted November 11, 2017 Share Posted November 11, 2017 I use a similar setup. My headphones also have the inline controls (extra band on the connector for the Mic). Anyway, I have to slightly pull the plug out from the adaptor, just barely. all the way in and it will give me terrible output. After the adjustment, sounds fantastic. hope that helps. Quote Link to comment Share on other sites More sharing options...
revera Posted April 14, 2018 Share Posted April 14, 2018 I have the same problem with using headphones. I am using an adapter as well but still don't get any sound in the phones. Have tried 3 sets of phones so far. Thanks Quote Link to comment Share on other sites More sharing options...
CharlesThomas Posted December 8, 2018 Share Posted December 8, 2018 From the Manual: *NOTE: The level and signal present on the XLR and 1/4-Inch outputs is dependent on the setting of the OUTPUT MODE button. Just to the side of the Left/Mono 1/4 output, there is a small "button," This needs to be in an "out" position for the headphones to work. I had the same problem. Tyler from Sweetwater helped me find this out. :) Quote Link to comment Share on other sites More sharing options...
MarQoPolo Posted March 31, 2019 Share Posted March 31, 2019 Hey guys, I have a different problem using headphones: It is only mono output ?! I don´t see why a headphone output should be mono. Is there some setting to change it to stereo output? Thanks in advance for your replies! Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted April 1, 2019 Share Posted April 1, 2019 12 hours ago, MarQoPolo said: Hey guys, I have a different problem using headphones: It is only mono output ?! I don´t see why a headphone output should be mono. Is there some setting to change it to stereo output? Thanks in advance for your replies! It IS stereo out. Are you sure you're headphones aren't damaged or that the plugs are all securely in place? Quote Link to comment Share on other sites More sharing options...
