willjrock Posted December 18, 2017 Share Posted December 18, 2017 Title says it all. I cant really think of any logical reason to change this somewhat predictable and efficient process. Ive tried most i could think of. How do we remove the parenthesis when needed? Why change the process? Quote Link to comment Share on other sites More sharing options...
duncann Posted December 18, 2017 Share Posted December 18, 2017 I've noticed this as well, because I sometimes accidentally assign a parameter to a snapshot. Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 18, 2017 Share Posted December 18, 2017 Just right click on the parameter to bring up the controller menu for the parameter you want to un-assign and select “noneâ€. Not quite as fast, but still pretty fast. Quote Link to comment Share on other sites More sharing options...
willjrock Posted December 18, 2017 Author Share Posted December 18, 2017 I can only assume it was un intended since i didnt see anything in the release notes. Is there any way to do it in the editor at all now? Quote Link to comment Share on other sites More sharing options...
willjrock Posted December 18, 2017 Author Share Posted December 18, 2017 Just right click on the parameter to bring up the controller menu for the parameter you want to un-assign and select “noneâ€. Not quite as fast, but still pretty fast. Thanks Phil...Maybe a bit of a different thing. Im not talking about the function that dictates WHICH controller it is linked to, but the step before that that defines whether or not the values are linked at all. Alt+click "arms" the function, or deems it ready for use. Then by default, the user can change the value of that parameter, via the snapshot menu. Yes you can right click on it to choose a different controller, but in my case we need nothing more than to be linked to snapshots. In all past editor versions, to opt back out of that menu entirely, so that NO controller including snapshots is "armed", alt+shift+click would undo what the previous alt+click did in the first place, or "DIS-arm" the linked parameter, or said yet another way, remove the brackets/parenthesis from the value of any parameter. :unsure: :blink: That function is no longer there and is not only imperative but was perfectly implemented for ease of use. Appreciate your input. I hope that makes more sense. Alt+click "arms" the function, then user has to decide whether that should Quote Link to comment Share on other sites More sharing options...
willjrock Posted December 18, 2017 Author Share Posted December 18, 2017 Just right click on the parameter to bring up the controller menu for the parameter you want to un-assign and select “noneâ€. Not quite as fast, but still pretty fast. Oh dude, im so sorry. I did not ,and could not see "none" :ph34r: Quote Link to comment Share on other sites More sharing options...
