morin0094 Posted January 3, 2018 Share Posted January 3, 2018 Hello there, I'm using HD500 USB plugged as a soundcard with Reaper + Guitar Rig for sound modulation. As output, I plugged my headphones on my HD500. My problem is that I still hear the "clean" sound in my headphones mixed with the distortion from guitar rig, and it kinda sucks. When I hit the record button, everything is fine on the take. I only hear distortion. Can anyone help me? Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted January 3, 2018 Share Posted January 3, 2018 So it's all fine after recording? Or do you hear the clean through your headphones during play back of the recorded track? And when you are playing without recording? It sounds like a monitoring function in your DAW is set to on position Quote Link to comment Share on other sites More sharing options...
Triryche Posted January 3, 2018 Share Posted January 3, 2018 Are you using standalone or plug-in? Quote Link to comment Share on other sites More sharing options...
morin0094 Posted January 3, 2018 Author Share Posted January 3, 2018 So it's all fine after recording? Or do you hear the clean through your headphones during play back of the recorded track? And when you are playing without recording? It sounds like a monitoring function in your DAW is set to on position Yes, in my mix everything is fine. Otherwise, I always hear the clean sound in the play back AND without recording. Are you using standalone or plug-in? I use the VST plug-in Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted January 3, 2018 Share Posted January 3, 2018 http://dlz.reaper.fm/userguide/ReaperUserGuide512c.pdf Section 3•5 of the reaper manual touches on input monitoring. Give it a try Quote Link to comment Share on other sites More sharing options...
morin0094 Posted January 3, 2018 Author Share Posted January 3, 2018 http://dlz.reaper.fm/userguide/ReaperUserGuide512c.pdf Section 3•5 of the reaper manual touches on input monitoring. Give it a try I tried all of the options, nothing seems to fix my issue Quote Link to comment Share on other sites More sharing options...
Triryche Posted January 4, 2018 Share Posted January 4, 2018 Just for clarification: In Reaper you are selecting Line6 ASIO as your I/O device. You insert an instance of GR on your recording track. Turn on Monitoring for that track. Arm track to record. Quote Link to comment Share on other sites More sharing options...
morin0094 Posted January 4, 2018 Author Share Posted January 4, 2018 Just for clarification: In Reaper you are selecting Line6 ASIO as your I/O device. You insert an instance of GR on your recording track. Turn on Monitoring for that track. Arm track to record. Exact. And my headphones are plugged into the "Phones" out of my HD500 Quote Link to comment Share on other sites More sharing options...
